SGS windshield change question
Old Nov 15, 2013 | 06:25 AM
ejvette's Avatar
ejvette
Default SGS windshield change question
This is my first bat wing.... to swap out the shield do I just take out the 3 retaining bolts/screws or do all the bolts holding the fairing cover need to be loosened or removed?
Old Nov 15, 2013 | 06:30 AM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
Just loosen the screws enough to pull the old one out and slide the new one into place. Snug the 3 screws down and you're good to do.
Old Nov 15, 2013 | 07:43 AM
ejvette's Avatar
ejvette
So just the 3 screws at the shield not all the fairing screws is that what your saying?
Old Nov 15, 2013 | 07:53 AM
BradMc's Avatar
BradMc
Thats correct, just the front 3 screws is all thats required to change screens.
You learn something every day, i have always removed the screws, didnt realise you could change screens by just loosening them.
Old Nov 15, 2013 | 07:56 AM
Nick508's Avatar
Nick508
What screen are you planning to put on it?
Old Nov 15, 2013 | 07:57 AM
FenderGuy53's Avatar
FenderGuy53
YES. Simply loosen the three (3) torx screws at the upper edge of the outer fairing. Grab the windshield from its outer edges and lift it out.
When you replace the windshield, use only an extension on your socket (not the wrench itself), then hand tighten; it's very easy to break the fasteners inside the fairing.
Congrats on the new Glider!
Old Nov 15, 2013 | 08:02 AM
Geoff's Avatar
Geoff
Do not over tighten the 3 screws after you mount the new windshield. As mentioned above, just snug 'em.
Old Nov 15, 2013 | 08:18 AM
ejvette's Avatar
ejvette
I have a 7" windsplitter coming thanks for help it's much appreciated
Old Nov 15, 2013 | 08:27 AM
Nick508's Avatar
Nick508
The reason i asked. When i replaced mine with the klock werks screen, i felt a huge difference. Almost 70% of the "dirty" wind was gone, but, it changed the handling on the front end, BIG TIME. It took a couple of rides for me to get used to the new ride..
Old Nov 15, 2013 | 09:04 AM
Bjc7Jr's Avatar
Bjc7Jr
More down force on the front end? I never thought it would be that significant....
