swapping to chain drive
Old Nov 17, 2013 | 07:56 PM
gremlinsteve's Avatar
gremlinsteve
Default swapping to chain drive
im thinking about doing the swap on my new bike.
looking for a little beter gearing and think that since this 70 tooth rear is unobtanium right now in cush drive bikes, ill just do the chain swap.
ive done it before on non cush bikes....
any do this wap already? im looking for a little better gearing while i am doing the swap so i am leaning towards going with a smaller than 21 tooth trans sprocket.
thinking about a 17/55 combo. i ride two up most of the time
Old Nov 18, 2013 | 01:15 PM
JCleary's Avatar
JCleary
Drago's sells a conversion that reuses your stock cush drive. There are a couple other offerings, but the names are slipping my mind at the moment.
My buddy did it in '09 on his '09 FLHX. It was a PITA, using a Softail hub on a PM rear wheel with some machined spacers and an offset front sprocket. The "plug and play" version using the cush drive is what I'll do on my Road Glide.
Either way the chain adjustment sucks. The axle is either too far forward, or too far back. So you need this:
http://www.rbracing-rsr.com/swingarm.html
ON EDIT-
Here's one that I couldn't remember:
http://www.pmfronline.com/bagger-chain-drive.php
Old Nov 18, 2013 | 03:11 PM
grbrown's Avatar
grbrown
Exclamation
Well a 17T is way too small! Chain efficiency plummets as tooth count goes down, due to the extreme wrapping of the chain around such a small sprocket. The 24T shown on the link JC gave is more like it. And then 17/55 is way off as well! That corresponds to 3.23:1, which is around the overall gearing of a dresser, not the belt/secondary drive.
So let's start again. What would you like to achieve with your gearing change? Leave us to work out the sizes that will do that!
Old Nov 18, 2013 | 03:43 PM
JCleary's Avatar
JCleary
Yeah, a 17 won't even come close to fitting. We've tried various gearing combos, and even with a 23 the chain rubs the trans case. We ended up having some custom sprockets made for the rear (offset similar to FXR sprocket, but sizes available are limited) in order to find the perfect gearing. IIRC 24/53 worked pretty well. But who wants to pay $500+ for a hardened chrome sprocket? LOL
Personally for a drag-racing bagger I think a 5-speed is superior. It's hard for a 6-speed twinkie to outrun a 5-speed, all other things being equal.
Old Nov 18, 2013 | 04:29 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
better ways to change gearing,smaller trans pulley,and\or bigger clutch basket gear.u can get the clutch basket gear from evo industries,chains suck always stretch and make noise and sling grease.
Old Nov 18, 2013 | 04:38 PM
Shovelhed's Avatar
Shovelhed
I like my chain rear drive. No probs and I've broke belts before. Primary and rears. Never broke a chain.
Don't remember what tooth it is though.
Old Nov 19, 2013 | 05:20 AM
grbrown's Avatar
grbrown
It could help if you recall what kit or brand you used. As for the chain versus belt debate, belts are the new chains!
superprohero
Oct 5, 2018 06:19 PM
TOMMYBLAZIN
Jun 26, 2018 11:41 PM
jeemann99
Jan 12, 2016 09:04 PM
Daddy454
Nov 11, 2015 03:58 AM
texashillcountry
EVO
15
Jan 5, 2014 11:11 AM
