Drilling a 2014 Tourpak for the luggage rack pointers?
Old Nov 20, 2013 | 03:27 PM
jeffreydsilver's Avatar
jeffreydsilver
I would NEVER center punch a tourpak! Spring loaded or not, an EZ way to crack it! Do a rough measurement and place 4 pieces of masking tape roughly where the rack will mount on the top of the tourpak. Place the rack on the tape and position it perfectly. You can then outline the 4 positions on the tape, remove the rack and drill. The tape will keep the drill bit from walking as well as prevent any cracking. No need to over think the job.
Old Nov 20, 2013 | 03:46 PM
1st 96 ultra's Avatar
1st 96 ultra
and DON'T press very hard , if anything hold back on the drill a little , and I second the no center punch , never needed to either
Old Nov 20, 2013 | 05:41 PM
silverbullitt's Avatar
silverbullitt
There are marks on the inside of the lid. They are the exact measurements. I did one, taped the outside, drilled a really small hole in the center of the marks from the inside and then drilled the correct size from the outside. Perfect.
Old Nov 20, 2013 | 05:44 PM
1st 96 ultra
well is this new or have these marks been there all along ?
Old Nov 20, 2013 | 05:55 PM
seph10's Avatar
seph10
S.O.B.,,,the in side of the lid is marked?? S.O.B. I feel stupid now,,,but I never screwed one up,,luckey I guess,,LOL,,
Old Nov 20, 2013 | 06:00 PM
silverbullitt
Don't know if the marks have been there before 14, just happened to notice them when I was ready to drill one for a 14 Ultra.
Old Nov 20, 2013 | 06:23 PM
Just Me's Avatar
Just Me
Exactly what I have always done and works flawlessly.
What does a new rack cost these days? Got mine free by crying it didn't have one when I purchased the bike.
Old Nov 20, 2013 | 06:36 PM
Uncle Paul's Avatar
Uncle Paul
Like the placing the rack on masking tape, and marking the spots idea best.
I put a non Harley rack on mine, and put lipstick on the legs of the rack.
Put the rack where I wanted it to go, and when I lifted it up the marks remained.
Old Nov 21, 2013 | 04:26 PM
1st 96 ultra
will have to remember that trick , what color did you use , LOL
Old Nov 22, 2013 | 05:15 AM
nuages's Avatar
nuages
The marks are new for 2014.
Make the holes slightly larger than the instructions suggest....say one drill bit size up...this means that if you drill slighty off centre the bolts will still fit and this does not compromise the TP lid and the inside will still stay dry in wet weather. They often do this in the Dealers to avoid rack to bolt matching errors.
Once drilling is complete, match up the bolts to the threads on the rack...to make sure of a perfect fit before adding silicon for waterproofness. The bolts usually come with threadlock on them but you can always add more if it comes off in the 'matching the bolts to the rack' process.
