torque specs.
Old Dec 4, 2013 | 03:13 PM
hardheaded's Avatar
hardheaded
Default torque specs.
getting two different answers on the torque specs.for my compensator bolt on a 12 streetglide. two dealers say the updated spec. is 160 lbs. and two other dealers say 140 lbs. anyone know what the real deal is ? should i add red loctite to the new bolt that already has blue on it ?
Old Dec 4, 2013 | 03:22 PM
VETERAN75's Avatar
VETERAN75
Did you get a new compensator kit? If so the trq should be in the instructions. It may be possible they are giving you the trq for the OE compensator and 2 are giving for the newest SE compensator. Google what part number you have for installation instructions and see what it says.
Old Dec 4, 2013 | 04:35 PM
hardheaded's Avatar
hardheaded
replacing bolt on the stock 2012 compensator, which is a screaming eagle .
Old Dec 4, 2013 | 06:17 PM
hog-doc's Avatar
hog-doc
Spec is 160 ft lbs with 4 drops of red loctite, that said we've been torquing them to 190 for years, they still have been known to come loose at 160!
Old Dec 4, 2013 | 07:07 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
use green 601 loctite and you'll need a plasma cutter to take it off the next time... but it is never going to loosen up...
ONLY KIDDING ABOUT THE GREEN 601, don't use it, stuff is stronger than a weld
Old Dec 4, 2013 | 09:23 PM
hardheaded's Avatar
hardheaded
well, i called the factory today and after much looking and asking other techs i was told the torque in the service manual is correct at 140 lbs. final torque. they knew of no update of torque specs. for the 2012 bikes using the screaming eagle comp. that came stock on them.
Old Dec 4, 2013 | 10:41 PM
VETERAN75's Avatar
VETERAN75
Where did you get the 160 lbs from?
Old Dec 4, 2013 | 10:46 PM
soft 02's Avatar
soft 02
Hit it with a 1/2 impact for 2 seconds and call it good.
Old Dec 4, 2013 | 11:26 PM
Guntoter's Avatar
Guntoter
Oh no you dint! I can hear the screams of the **** retentive and torque obsessed members now............
Old Dec 5, 2013 | 12:58 AM
ke5rbd's Avatar
ke5rbd
I have one waiting to be installed. Not the new version. This one comes with the stator rotor. It says torque to 100lbs the loosen 1 round then retorque to 140lbs. The 3 drops of red locktite are a necessity. Friends came loose twice until the dealership put red locktite on it.
