if you have any indys in your area check them out. One of the 3 in my area has a tire & balance machine and does it for cheap if you bring in the tire & wheel. He did my front in 10 minutes for $10.00.
An Indy close to me charges almost the same as the internet prices for the tire. If I buy the tire from him he does not charge for mounting and balancing. Dropped off wheels at 6:00 at night he called me at 8:00 next morning to pick them up. I would call local Indy dealers before doing anything.
Local Indy told me he doesn't make any money selling tires and I should buy them online and bring them to him to change/mount/balance. 50 bucks a wheel on the bike. I don't/can't do much of myown work anymore and he also installed my sceam'n eagle 103 jugs/pistons, Andrews cams, Front springs + ricor valves plus lots of other parts I bring in. Parts not warranty but labor is. I keep going back... Had another great guy that did service work in his garage I took tires to but he moved to the hills. Looks funny to ride around with a tire around your neck...
Local dealer here will remove the wheels, install, and balance new tires, tubes, and bands if purchased from them...... For no labor charge........ No brainer for me. I know the MSRP price vs. internet price with a charge for install and balance...... along with time for me to remove the tires....... All the same in the long run.
They have an express lane on saturday....... get there early and be out of there in an hour or two.......
Bring the wheel in yourself to an indy. Don't have them balance and they should charge you a few bucks less. Buy Ride-On to put in the tires for punctures sealing and balancing. GREAT stuff and no weights.
For years I have ridden to one of several local shops, tire or motorcycle, that will remove wheels/tires, mount tires bought there, and install them on the motorcycle. This is included in the price of the tire.
I buy my tires on line for lot less $$$ then Hd shop then either take to HD or Cycle Gear who ever can do right away,balancing is very important for proper handling. Installing wheel back on the bike follow directions and all torque specs strictly to the repair manual for YOUR SAFETY.
Local dealers will not mount outside sourced tires in my area.
Local dealers will not fix a puncture even on tubed tires in my area.
Local dealers wanted $200+ for the change-out, mount,balance of two tires and two tubes.
Took bike into an indy and picked it up a couple of hours later for $200+ less than the dealer (who did not include the rear pads in their price) including replacement of rear brake pads for the same exact tires, non harley tubes and name brand pads.
To be fair the Indy does not supply coffee, doughnuts or wash the bike.
Some places advertise inexpensive tire prices but the gotcha comes in installation cost.
Total cost is the key..
If the dealer would have been only a hundred difference i would have given them the job and used some chrome points but $200+ not including rear brake pads is out of line for me.
To be clear the dealer would be an additional $200+ dollars above indy total cost and would not include parts and installation of rear name brand pads.
