Oil temperature gauge problem- need help
Old Dec 16, 2013 | 01:12 PM
HD32141's Avatar
HD32141
Default Oil temperature gauge problem- need help
My 2010 Classic has had a oil temp gauge since a month after I bought it. I switched to silver gauges yesterday. Here is the problem:
The 2010 gauge had posts so the sensor's harness has crimp on ring ends. The new gauge takes a plug. I need the plug to splice my sensor's harness to. The dealer can't seem to help.
Anyone been through this before?
Old Dec 16, 2013 | 01:53 PM
Weavr99FLHT's Avatar
Weavr99FLHT
#69200297 is the harness for the oil temp gauge. It is clearly stated in the instructions provided with the oil temp gauge. Looks to have plug on both ends .
Old Dec 16, 2013 | 02:02 PM
HD32141's Avatar
HD32141
Yes- I got this in my kit. But it doesn't plug into the gauge, it won't fit. It must plug into a jumper. A short piece that plugs into the gauge...
Consequently, I just left the harness I already had on the bike. Because I need the piece that plugs into the gauge. I can splice it to the existing harness where the ring ends are.
Old Dec 16, 2013 | 02:46 PM
Weavr99FLHT
Originally Posted by HD32141
Yes- I got this in my kit. But it doesn't plug into the gauge, it won't fit. It must plug into a jumper. A short piece that plugs into the gauge... Consequently, I just left the harness I already had on the bike. Because I need the piece that plugs into the gauge. I can splice it to the existing harness where the ring ends are.
So, your new gauge came with a harness that doesn't fit the new gauge? Turn the harness around and try the other end.
Old Dec 16, 2013 | 05:06 PM
HD32141's Avatar
HD32141
What I received in the kit is a 2-wire harness (black and yellow wires). One end plugs in to the sensor in the block. IF the other end WOULD plug in to the gauge, where would the 12v power come from to illuminate the gauge?
What am I missing?
There IS a jumper wire 32806-00 in the kit but it's also a 2-wire harness (brown with green tracer and green with yellow tracer). I am assuming this connects to give the gauge power.
If I am right then there's a jumper that would go into the gauge with 2 plugs on it.......
Old Dec 16, 2013 | 06:09 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Normally, you would use the lead used for the air temp gauge and sensor to complete the connections. The connector that plugs into the back of the air temp gauge (the gauge which is usually removed to make a hole for the oil temp gauge) is supposed to plug into the rear of your new oil temp gauge. The other end of that lead is unplugged from the air temp sensor (air temp sensor located on the left front upper frame) and then plugged into the lead coming up from the oil temp sensor in your oil pan.
Your oil temp gauge will have 1/4" spade terminals on the rear.....the top set for the bulb in the meter and the bottom three for the signal from the oil temp sensor. Polarity markers are beside the terminals so you can get positive and negative correct for the meter movement feed. Polarity does not matter for the bulb.
If your current connections are ring terminals, then simply cut them off and change them to female 1/4 spade connectors and you can hook them right up to the rear of the meter.
Old Dec 16, 2013 | 07:02 PM
HD32141's Avatar
HD32141
I read what you wrote but...
the gauge I had only had 3 posts with nuts on them. You are saying 5 connections? I thought this.
Can I just buy the plug that goes to the gauge?
Old Dec 16, 2013 | 07:27 PM
sanman4ever's Avatar
sanman4ever
Can you provide pictures, that might help.
Old Dec 16, 2013 | 07:37 PM
Lowcountry Joe
Sure you can if you research the plug and then purchase it from an electronics supply store. You have already said that HD is useless to help you. But if it were me, i would say to hell with the damn plug and solder on some 1/4" spade connectors and be done with it in about 10 minutes.
Old Dec 16, 2013 | 08:16 PM
UltraClassicElectraGlide's Avatar
Here's a link to the pdf instructions if it helps answer any questions.
https://dl.dropboxusercontent.com/u/...structions.pdf
