(fl-af-xied-10)
Old Dec 23, 2013 | 12:30 PM
Ridewva's Avatar
Ridewva
The first mod I do is change the airbox/backing plate to allow better breathing because that's traditionally been the biggest restriction, like 50% more improvement that adding slip-ons. However I believe I've seen here the new style airbox on the 2014's is not as restrictive so little to nil gained by changing it (on a stock motor).
Nice to hear the fl-af-xied-10 functions well!
Old Dec 23, 2013 | 12:35 PM
tn_chopper_man's Avatar
tn_chopper_man
Originally Posted by oakmossy
I feel that the stock a/c's on '14's are stage 1 level anyway. anyway that what my dealer tells me. Without a dyno test who knows?
DITTO....That's the same thing my dealer told me.
Old Dec 23, 2013 | 02:47 PM
TUCCI's Avatar
TUCCI
The 4" pipes already added a significant lean condition to your fuel mixture, if the XIED solved that then more power to you....but, if you further increase the lean mixture by adding more oxygen with a stage 1 AC (air cleaner) the XIEDs may not be able to compensate enough fuel to solve the popping condition if it returns. Thats why you were told to quit while your ahead...hope this helps.
Old Dec 23, 2013 | 03:36 PM
jim518's Avatar
jim518
If the cat is still in, there will still be lots of back pressure. The VIED's are adjustable, don't think the XIED's is. If you remove the cat you will lose some bottom end torque and possibly get more noise then you want with your slip ons. If your not gonna remove the cat and like the stock breather cover, why not wait till K&N comes out with a filter.
Old Dec 23, 2013 | 03:42 PM
14 FLHX's Avatar
14 FLHX
subscribed, i have my eyes on the xied/vied also.
Old Dec 23, 2013 | 03:43 PM
Gunnysgt's Avatar
Gunnysgt
I run the FL VIED with my '14 limited, stock headpipe, SE Street Cannons and STage 1 a/c, no problems, VIED can be adjusted to it.
Old Dec 23, 2013 | 04:50 PM
my67pnycar's Avatar
my67pnycar
Put the xied's on it, set it and foget it.
Old Dec 23, 2013 | 05:11 PM
sixguns's Avatar
sixguns
As info, I had the stage 1 download done with a D&D slip-on and SE stage 1 AC put on my 2013 FLD when I bought it new, It had decel pop like crazy. I installed the XiED and got all the benefits as advertised, no change on the pop. Fast forward to my 2014 Road King, stage 1 down load done with V&H slip-on's and stage 1 SE AC no decel pop. I put on the XiED from the old bike and it runs great.
Old Dec 23, 2013 | 05:36 PM
user 8373900's Avatar
user 8373900
I'm not trying to be smart assed here, but you are going to have to explain how in the world a pair of slip-on mufflers, behind that catalytic converter would EVER change anything related to mixture. You said lean condition, which it may be, but mufflers alone will make no difference in the AFR especially with the cat in the way.
Mark
Old Dec 23, 2013 | 05:49 PM
willryder's Avatar
willryder
I have the fl-af-xied-10. They are adjustable.
