Help Remove/Replace Rear Wheel
Old Dec 25, 2013 | 09:33 AM
Skippy97's Avatar
Skippy97
Default Help Remove/Replace Rear Wheel
Hey All,
Thanks up front for the help!
I want to save some cash, so will be taking off the rear wheel myself for a tire change at the dealership (for the future, will be looking for an Indy I can use for tire mounting…another $50 or so savings).
So, have watched a video or two, but want to get "been there, done that" help.
From tools, remove, to replace…what are your lessons learned from your own experience with rear wheel removal?
I bought a 36mm Kastar wrench. I have a center lift for the motorcycle, and was thinking of using my car jack to help lift/lower the rear wheel into/out of position.
Thanks again for any help!
Skippy
Old Dec 25, 2013 | 09:38 AM
Stiggy's Avatar
Stiggy
Put an upside down bucket or similar object under the front wheel so when you remove the rear wheel, the weight shift to the front doesn't wobble the bike. Your 2011 is different form my 2000 so I'll leave those wheel removal instructions to other posters. Good Luck.
Old Dec 25, 2013 | 09:40 AM
SpiderPig's Avatar
SpiderPig
Originally Posted by Skippy97
Hey All,
Skippy
Just a suggestion; Be sure to support the front tire with either another jack or anything that will eliminate the front of the bike from taking a nose dive after you remove the rear tire. As the bike will become tipsy if not supported. Mark your axle cam position with tape or white out.
Also use some anti-seize on the axle when you reinstall.
Old Dec 25, 2013 | 09:41 AM
prezflyr's Avatar
prezflyr
I just changed my rear wheel bearings and you have the right idea. Bucket in front and jack to help with lifting and you will b fine. I suggest removing bot mufflers as well. You may want to change your real wheel bearings while you are down. I had front failure a few months ago and changed my back just for insurance.
jmpancoast's Avatar
jmpancoast
Pretty straight forward. Few suggestions:
    • Masking tape edges of rims to protect from scratches
    • Use white-out or grease pencil to mark eccentric on clutch-side of axle and swing arm for proper belt tension
    Old Dec 25, 2013 | 10:25 AM
    Wanna Ride's Avatar
    Wanna Ride
    It's likely you may not need to remove the exhaust at all. You might get lucky by just loosening the support hangers and working around it.
    Others may have already told you this with other inquiries as well, but the service manual can really prove helpful with these types of projects. They provide illustrations, torque specs, etc.
    Someone else already mentioned the belt tension. That's pretty critical to longevity, so it's important to be correct. Saving money by doing these repairs can often provide you the experience and better knowledge of your bike. That knowledge and experience will also make you a better rider, by better understanding how your machine works.
    When I first started riding, I took advantage of these savings and spent the money saved, on service manuals, and the specialty tools to properly and efficiently do the work myself. Some guys will say that you don't need to spend $25 on the belt-tension tool, but after purchasing one and knowing how to use it, all doubt on the belt tension being correct or not, is completely removed. And now you own it, and can perform the check/ adjustment at your service intervals. One more step towards being independent, and not relying on a dealership. The manual usually goes for about $60-$70, and is a wealth of information on this, and many other easily performed tasks. It didn't take long to acquire a lot of specialty tools, a couple service jacks and a new table-lift, by learning how to do mods, service, and repairs by myself. All by saving money as well.
    But just as some advice, you have to get the rear of the bike pretty high off the ground to get the rear tire clear of the fender. As others have said, chocking something under the front tire is almost a must if all you have is a service jack, with no table-lift.
    Old Dec 25, 2013 | 10:49 AM
    Army Vet34's Avatar
    Army Vet34
    6th Gear
    You can use just grease on the axle too.
    Old Dec 25, 2013 | 10:53 AM
    Imold's Avatar
    Imold
    When the bike is jacked where you want it and the jack safety stops are engaged, make sure you tie it down good and tight; might seem solid sitting on the jack (some jack companies claim you don't have to tie it down), but why take chances.
    And to elaborate on previous suggestions -
    Coat the whole axle except what sticks past the bearing on the outside with anti-seize, even where it doesn't contact metal, will help prevent rust. If you use anti-seize like me, you'll buy the bigger cans, not the tiny tubes, cheaper in the long run.
    Unless I put them in last time, I change wheel bearings with tires, and always pry a plastic seal up so I can see that they have enough grease (yes, manufacturers can miss putting grease in - I've found a couple) and don't have plastic bearing cages. I replaced a wheel this summer that came with new bearings installed - they had plastic cages. Wheel got it's second set of bearings before it's first tire...
    Old Dec 25, 2013 | 11:11 AM
    Notgrownup's Avatar
    Notgrownup
    I undo both rear muffler brackets at the back just so the pipes will lower enough to get the axle shaft out...On the 08 and up you can take the brake caliper off first, not on mine...I use disk brake bearing grease on my axle but anti seize is fine also...Mark the cam for belt tightness but also check it...My indy charges me $20-$25 per wheel so i will keep going there...
    Old Dec 25, 2013 | 11:12 AM
    Imold's Avatar
    Imold
    Don't have any photos with the Glide on it, but this one with a sporty shows that this jack has no problem lifting a bike high enough to clear a wheel. The wider lifting arms and base legs won't let the bike tip, either. It has a lowering valve sensitive enough you can lower it really slow, makes it easy to line up axles.
    No horsing around the wheel, just drive the axle in with the holes lined up. And yeah, my grandkid did it while I guided it through the other side. Kids love hammers...
    "I know what I said before, but you can hit it this time, really - just don't hit anything else..."
    more with the kid here: https://www.hdforums.com/forum/members/178920-imold-albums-52275-my-mechanic.html
