First be sure you have the most current software and firm ware loaded to your pc and pcv. You will have to connect the pcv to the pc and enable the autotune. You will also then have to setup the autotune. Based on your setup of the autotune (temp, etc.) you will be able to see the AT working ( when the pcv is attached to your pc) on the pc monitor. The DynoJet web site and the software "help" have a good overview of how to setup the AT - my advice would be to start there and make a few notes because there are many setup options to adding the AT. Also do a search of the forum. Iclick has a very good writeup.
Thanks,
Was unable to ride today because of rain but did ride about a half hour Friday after installing the Autotune. No trims were recorderd, checked the can, O2 connections, status light runs a 3 blink sequence with a pause at the end. It does this 3 times and then the light stays on solid.
Have read just about all I can find and watched multiple videos.
I watched a Dynojet video about adding devices to the network but it does not show the Autotune on the network
