HELP!!!! I think I screwed up!
Old Jan 1, 2014 | 08:10 PM
usmc97hd's Avatar
usmc97hd
Default HELP!!!! I think I screwed up!
About an hour ago I pulled the ignition switch out of my 09 Ultra so I could remove the switch housing and raise my handle bars. I watched the video on how to do it. It came out no problem. Now going back is a different matter all together. It wouldn't go back in and the more I fiddled with it the worse it got. Got it in but it wouldn't start. Got it in and it would start but wouldn't stay in. Then it sparked from my keys hitting the dash and blew the maxi fuse. Im on my way the buy fuses now. I don't think its supposed to spark. What have I done and how do I fix it?
Old Jan 1, 2014 | 08:12 PM
dawg's Avatar
dawg
Getting it back is one issue, but no it shouldn't spark. You have a wire grounding out on your ignition post somehow. Find that and take care of that first then worry about aligning the tumblers.
Old Jan 1, 2014 | 08:24 PM
Gunnysgt's Avatar
Gunnysgt
Several of us have been there, me included a few years ago. Once you remove that switch, if you turn that ignition at all without the special Harley tool, the parts in there misalign and all hell breaks loose. The one time I did that I went to a local dealer and borrowed the tool, realigned the parts and took the tool back. You can make one of those tools, there are threads on here, but you oughta actually see one first
Old Jan 1, 2014 | 08:25 PM
dawg's Avatar
dawg
You can also buy a tool for $25
Old Jan 1, 2014 | 08:32 PM
Guntoter's Avatar
Guntoter
Although some members here have said this tool is unnecessary, I have found it to save a lot of hassle and frustration.
http://www.marcparnes.com/HarleyIgnitionSwitchTool.htm
Old Jan 1, 2014 | 08:39 PM
RK_2014's Avatar
RK_2014
+1 on any Marc Parnes products
Old Jan 1, 2014 | 08:41 PM
murph's Avatar
murph
That's whay I did. When I take out my ignition for any reason, i place the tool in its place for many reasons. One, so the tumbles stay aligned. Well worth the 25 bucks
Old Jan 1, 2014 | 08:42 PM
sonnlaw's Avatar
sonnlaw
Look inside with a flashlight and align the tumblers with a screw driver. I was in your shoes just last week. It WILL work.
Old Jan 1, 2014 | 08:50 PM
MarcV125's Avatar
MarcV125
deep breath and you will get it...i used the flashlight and screw driver method also...The sparking and blowing a fuse though?.. Not sure there..can you take a picture of the ignition switch housing internally...May be hard to take a picture of, but there must be something exposed to cause it to spark.?..
Old Jan 1, 2014 | 09:39 PM
sprint07's Avatar
sprint07
Wouldn't the instructions normally used for switching the inner fairings work also?? I recently did an painted inner fairing swap using the instructions I found on this forum and had no problems taking the ignition out and putting it back in??
