Chrome Front End Parts List
I'm Currently collecting all the parts for a chrome front end on my 09 street glide - having a friend do the install, looking for advice on the list of parts required, here's what I have got
***** Shinny fork legs (exchange program)
Chrome cow bells
Polished rotors (***** shinny)
SE heavy fork oil
(And I have a service manual!)
My question is what seals/ O Rings/ nuts bolts etc will I need and furthermore, while this front end is apart is it worth throwing a set of Progressive Mono Tubes in to beef up the front suspension - for $350 maybe a good idea?
Any other parts I've over looked please feel free to berate my stupidity!
Amazingly I went to my local HD dealer to ask for advice and they were less than helpful as I wasn't purchasing the HD full kit, and installation from them.....
As always thanks for the help in advance.
Ride Safe.
Chrome Front Wheel Spacers - 41458-08, $39.95
Front Axel nuts - 45813-03, $7.95
Chrome drain screws (copper washers included) - 45848-03, $3.95
Fork Oil seals - 45875-84A, $15.54
6mm Screws (copper washers included) - 45405-75A, $2.00
Fork tube oil seals - 45733-48, $1.14 (not needed with mono tubes)
I believe all the price quotes are from Ronnie's.
In addition, get the mono tubes. I ended up doing mine twice due to not going the monotube route the first time. It makes the install alot easier as well. Compressing the stock fork spring is work. Easternpc has the monotubes for $250.
What brake pads are going going to be using with those chrome rotors?
Word of caution: You'll soon discover you need a chrome wheel, chrome calipers, and a different fender to show it off.
As for the break pads - I have polished stainless rotors so I was going to run my stock pads to start with, if they squeal excessively then try an EBC set
Btw I will get a set of mono tubes thanks for the tip on the EP $ - do mono tubes require oil? Or are they self contained and pressurized units?
Also I would not use the stock pads with a polished rotor. Might mark them up. For me I went with Lyndall Zplus pads. My experience with the EBC's was to much brake dust.
The mono tubes only require 5 ounces of 10wt fluid each leg. It's more for lubrication since the mono tube is a closed loop cartridge set up. I do see posts where people use the SE oil in them. I installed per Progressive specs.
