Gutted CAT temperature difference...
Old Jan 12, 2014 | 09:31 AM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
Default Gutted CAT temperature difference...
Has anyone actually measured the temperature difference at the CAT area before and after removing it on the stock head pipe? I have a 2014 Ultra and not necessarily concerned with performance or sound increase, (yet). Thanks, AL
Old Jan 12, 2014 | 10:31 AM
dennyo's Avatar
dennyo
.... Nope can't Help Ya on that BARACU , But the 4T-9ers are Playin this Mornin ...
Old Jan 12, 2014 | 10:36 AM
Rickl's Avatar
Rickl
I can't provide specifics but it was enough to tell a significant difference . . . to me! Re-mapping with a power vision has now made it very bearable. (Not much different then my wing blowing the heat off the radiators.
Old Jan 12, 2014 | 10:42 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I replaced the head pipe in my 2012 bike to get rid of the cat. I had a oil temp dipstick, and noticed only a small change in actual engine temp according to those readings. My wife did report a dramatic drop in exhaust temps that she had to deal with.
Old Jan 12, 2014 | 10:46 AM
davidwruth's Avatar
davidwruth
+1 on wife liking the change. No actual measurement. Sound changed as well
Old Jan 12, 2014 | 11:10 AM
ThisIsCrazy's Avatar
ThisIsCrazy
I had a shop cut out the side and gut it on my 2014 FLHXS and the sound was the biggest change. I did notice a change in temp radiating on my foot.
Old Jan 12, 2014 | 12:23 PM
0ldhippie's Avatar
0ldhippie
There was a thread a while back where folks were measuring exhaust temps. Don't recall it being very useful? I have a bad memory though??? It will do nothing for engine heat, only the Cat heat (1000F+) from the collector. I've never had a cat, but exhaust heat on some new bikes is crazy hot, but also seems hit and miss? My '09 EG burned my right calf, couldn't keep my foot on the footboard (fixed with Fullsac header and ceramic coated shields). My brothers '09 RK never had a heat problem. Buddy's '12 trike is crazy hot, other buddy just got a '14 Limited and it is cool?
Old Jan 12, 2014 | 12:30 PM
oakmossy's Avatar
oakmossy
I wonder if there is anything about the design of the '14's that would make the heat issue mo' better?
Old Jan 12, 2014 | 12:46 PM
heavymetalthunder's Avatar
heavymetalthunder
I think the new cams make some difference. The water jackets help also on the Limited's.
Old Jan 12, 2014 | 01:10 PM
dribble's Avatar
dribble
I have. On an 80 degree day after a 20 mile ride, the temperature at the cat was recorded at 445 degrees. After replacing the pipe with an OEM cat-less header and doing no other mods, the temperature at the cat area measured 265 degrees. The sound changed slightly and not surprisingly, there was no change in performance
