2006 street glide oil pressure warning
Old 01-20-2014, 07:43 AM
joseriosquintana's Avatar
joseriosquintana
joseriosquintana is offline
Default 2006 street glide oil pressure warning
Hi, I live in Puerto Rico weather about 90 degrees when I ride my 2006 Street Glide with Stage 1 only with 8000 miles on it, my concern is that while I'm driving at normal speed with stop and go on traffic lights or on the highway my bike stays at normal oil pressure 15-32 when cool even higher than 32 but when in traffic for a while the pressure drops down to 0 and sometimes when I get to my destination I notice the red oil pressure warning blinking. After a while when I take of the pressure goes back to normal. The previous owner used 60 grade harley oil and formula+ on trans and primary and I went to the Harley dealer and they recommended SE Harley 20-50 sync on all 3 which I did and I am still having the same problem. Appreciate any suggestions.
Old 01-20-2014, 07:52 AM
Gliden's Avatar
Gliden
Gliden is offline
An oil pressure sending unit is about 30 bucks. Might give you piece of mind to change it or at a min....pull it and clean the end of it with a degreaser or lighter fluid. In real hot weather it's not uncommon for oil psi to drop to 5-8 psi. I'd swap the sending unit.
Old 01-20-2014, 08:21 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Check your owners manual, as it may recommend using a heavy oil for those temperatures. If you get over 80 degrees regularly I would use 50 or 60 grade, certainly not 20/50. That alone may restore your pressures to the levels Gliden mentioned.
Old 01-20-2014, 08:39 AM
valvestem's Avatar
valvestem
valvestem is offline
Here is the answer above. Your 20-50 (especially the brand you are using) is thinning too much in the heat, and it is not uncommon for the oil light to come on under those circumstances.
Old 01-20-2014, 08:46 AM
Joe_G's Avatar
Joe_G
Joe_G is offline
Also, what is your idle speed? When I slow my bike's idle down to enjoy the potato potato sound, I notice my oil pressure drops very low (I have a tach and a gauge). At 1000 rpm idle it has good oil pressure.
Perhaps the prior owner dropped idle below spec to sound cool. If so you could put it back to spec and likely solve the problem.
If you really want to know what your oil pressure is you could install a gauge, they are readily available from HD or aftermarket. I'd certainly do that before I tore into the engine.
Gary07
Oil Archive (no new posts)
03-22-2018 01:57 PM
IRATETINO
06-14-2010 03:08 PM
jarhead45
07-11-2009 01:23 AM
HD1st Bike
Welcome Area Only
07-05-2008 01:11 PM
fil
Shovelhead
18
10-18-2007 05:08 AM
Quick Reply: 2006 street glide oil pressure warning
