Oil Archive (no new posts) An archive of oil related questions and comments.
oil Pressure
Old Jul 31, 2016 | 05:36 PM
Gary07's Avatar
Gary07
2nd Gear
Default oil Pressure
Yesterday it was 103*. When i made a stop, I noticed that my oil pressure dropped to about 5# of pressure. When I took off, it went back to 28-32#. Is this normal, once the oil gets hot?
Old Jul 31, 2016 | 06:18 PM
TinCupChalice's Avatar
TinCupChalice
That's been my experience with multiple HD's with oil pressure gauges; make a stop for fuel with the engine fully heat soaked on a nice hot day and when you restart the pressure is going to read rather low. Start to bring RPM's up and the pressure is fine and as you begin riding and the engine cools the pressure is back at its usual reading; on this Wide Glide 103" that's 40 PSI with SAE 50 VR1 engine oil... you're good to go
No air flow at a stop and a heat soaked engine? That oil get's hot and it does affect your oil pressure readings when you first start the bike again...
Old Jul 31, 2016 | 06:23 PM
QC's Avatar
QC
Harleys run on volume, not pressure, so as long as the lights don't come on, you're good to go.
Old Aug 1, 2016 | 07:00 AM
TinCupChalice
Exactly; I certainly don't want to turn this in to an oil filter debate but one of the reasons I prefer permanent oil filters is the increased oil flow rates they offer. HD's run on their volume and I'll take all the added oil flow I can
Old Aug 7, 2016 | 12:07 PM
grbrown's Avatar
grbrown
Cool
Yes. My favourite indy hates oil pressure gauges and you can see why - they cause too may queries and 'problems'. Ride on and enjoy.
Old Aug 7, 2016 | 12:18 PM
2500hdon37s's Avatar
2500hdon37s
Same reason most new vehicles gauges dont show real numbers any more.... just a Low to high scale with the little red danger zone.
Old Aug 9, 2016 | 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When you ask a technical question, consider adding the model and year...
Old Mar 19, 2018 | 04:57 AM
95ragtop's Avatar
95ragtop
My 09 Street glide does same. After it's hot the oil pressure gauge drops when idle down at red light. Oil pressure light doesn't come on.
Old Mar 22, 2018 | 01:57 PM
golfish5's Avatar
golfish5
5th Gear
Hello to all Fellas' I have a 96" Twin Cam engine built in 2007. It has S&S cases, Andrews cams, everything else is HD. I must say that I'm not familiar with the Twin Cam engine. All of them that I look at have the oil pressure gauge in front of the engine, mine is towards the back where the feed, return and vent lines are, just like the Evo.
The pressure gauge reads zero, its been replaced with a new gauge and it reads zero as well.The oil flows free and speeds up when I twist the throttle. There's no noise at the top end and the bike been running like this for 10+ years (I bet the bike doesn't have 5000 miles on it)
I'm lost on this one. If somebody has and idea or maybe another website, please let me know.
Thank you
fish
radudel
Apr 18, 2016 01:38 PM
Medicjaycook
Aug 13, 2011 01:18 PM
IRATETINO
Jun 14, 2010 03:08 PM
fil
Shovelhead
18
Oct 18, 2007 05:08 AM
Ooknight
Mar 5, 2007 03:38 PM
