Help!
Old Jan 30, 2014 | 06:21 PM
Puggy's Avatar
Puggy
Default Help!
I think I've screwed the pooch but hopefully yall can help me out. I was taking apart the exhaust and accidentally dropped the nut off the crossover exhaust pipe clamp. I can't find it and I'm thinking it dropped into the hole above the belt pulley. If it did, how can I get it out?
I thought about jacking up the bike and rotating the rear wheel by hand to see if I hear it drop or something. Need suggestions fast.
Old Jan 30, 2014 | 06:24 PM
soft 02's Avatar
soft 02
Use a small mirror and a pen light.
Old Jan 30, 2014 | 06:25 PM
decencyxdefied's Avatar
decencyxdefied
turn the bike upside down.. lol
Old Jan 30, 2014 | 06:29 PM
spf62's Avatar
spf62
Old Jan 30, 2014 | 06:33 PM
Freebirdsride1's Avatar
Freebirdsride1
wedged around the starter area maybe us a magnet and go fishing. good luck
Old Jan 30, 2014 | 06:35 PM
1st 96 ultra's Avatar
1st 96 ultra
just look at all kinds of angles , you would be surprised how that stuff can hide , then all of a sudden it appears , or the gremlins give it back
Old Jan 31, 2014 | 07:19 AM
grbrown's Avatar
grbrown
I recently removed my rear fender and found several 'lost' items sitting on the swingarm lug at the rear of the trans casing. Roll the rear wheel forwards and backwards, just in case the nut has dropped onto the belt. Do that with the wheel off the ground and by hand, just in case the nut rolls into the pulleys. Otherwise use a magnet, as Freebirdsride1 suggests.
Old Jan 31, 2014 | 07:23 AM
nchogfan's Avatar
nchogfan
A good light and a magnet.
Old Jan 31, 2014 | 07:48 AM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
First sweep the floor......I've found nuts and screws 10 feet from where I thought they landed. If you can find it that way go to the hardware store and get one of those magnets on a telescoping rod. Put the bike up on the jack-stand so it's upright and start probing with the magnet. You will find it. BTW where is the screw-able pooch on a motorcycle?
Old Jan 31, 2014 | 07:53 AM
krwould's Avatar
krwould
Ole school but I throw a blanket on the floor under the bike... stops those nuts and screws from sliding across the concrete floors, better if your working out in a gravel driveway.
