they look badass.. Still gotta install the other end of the clutch cable and figure out why my throttle is tight.. starts and runs fine all the electronics work but the throttle doesn't snap back like it should
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
I just finished my Mayhems and had that exact throttle issue!
My Avon cushion grips were too tight on the throttle side - had your issue. I ended up putting a set of stock grips on in a pinch (was gagging to ride) what grips did u end up using???
I have the nostalgia grips.. Had them on my stock bars.. I'm gonna make sure everything is smoother where the tbw Sits n the grooves and spray some lube on it and see Wat happens.. either way I'm riding the **** tomorrow lol
I have a set of nostalgia's in the garage also... Should have thrown them on to try... Anyway the stock grips work fine. Will run them for a while. The mayhems are great btw!!
Before you go and put lube on it, loosen up your hand control housing and slide it to the right about 1/16". You've got it all pulled too snug. Your grip is bottomed out against the TBW and it's binding in your hand control housing. Just give it a little slack and all will be good. It's gotta have a little wiggle room.
