Windshield bolt torque
Old Feb 17, 2014 | 02:29 PM
Tripod2013's Avatar
Tripod2013
Default Windshield bolt torque
I have a 2013 Street Glide. I ordered a Cee Devil windshield from Cee Bailey's and have a question. A warning sticker on the new shield says to torque the shield to 3-5 inch pounds to avoid cracking. This seems a little on the light side to me as I have read anywhere from 20-30 inch pounds. It says 3-5 inch pounds would be about the same as tightening a water bottle cap. I can see not overtorquing, but 3-5 inch pounds?
Any thoughts??
Thanks, Tom
Old Feb 17, 2014 | 02:38 PM
digdug's Avatar
digdug
I also have a 2013 SG with a Cee Baileys windshield. I didn't torque any of the screws...just tighten to a normal tightness (which means tighten up to just before they break!).
Old Feb 17, 2014 | 02:42 PM
slammed05fatty's Avatar
slammed05fatty
i took mine offf and on tons of times, never "torqued" them, just tightened them using good judgement. didnt crank down on them. tighted them them till it gets snug, i would alternate between the 3 and get them even as you can.... or just get an impact and save time lol
Old Feb 17, 2014 | 02:44 PM
HDV-GLIDE's Avatar
HDV-GLIDE
and check/retighten them after your first ride because they will loosen up some......
Old Feb 17, 2014 | 03:36 PM
dawg's Avatar
dawg
Purple loctite. Easy to strip out, I just snug them
Old Feb 17, 2014 | 03:48 PM
Prime Rib's Avatar
Prime Rib
I just put a new windshield on my Electra Glide. I hand snug them.
Old Feb 17, 2014 | 04:10 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
My 07 Serv Man says 25-30 inch pounds... others may vary
Old Feb 17, 2014 | 04:24 PM
rick2800's Avatar
rick2800
Thats what my svc manual calls for also. 3-5 inch lbs seems light too me. Better take it off during locust season.
Old Feb 17, 2014 | 04:45 PM
rbferg's Avatar
rbferg
You can get all the fairing screws plenty tight by hand. Never crank down on them with a ratchet.
Old Feb 17, 2014 | 05:09 PM
K Melancon's Avatar
K Melancon
I use a screw driver with torq tip. I use my finger tips to tighten. This way I know I'm not over tightening. Snugged up is all I need. I start in the middle and work outward with your screws.
And I have tighten a water bottle by hand so tight that I could not get the cap off.
