Street Glide brake upgrade
Old Feb 19, 2014 | 11:18 AM
mdanehart's Avatar
mdanehart
Default Street Glide brake upgrade
I would like to upgrade the front stock brakes/calipers on my 2007 Street Glide, any suggestions with going $ overboard?
Thanks
Old Feb 19, 2014 | 11:35 AM
XARAN's Avatar
XARAN
Ive found a big improvement just changing pads to Lyndall and a floating rotor.IMO these bikes are 800 lb tourers and will never stop like a sport bike, the improvement with ABS, a good set of pads and a floating rotor to minimize fade stops my RG much faster and safer than any HD Ive owned before and the cost was only a couple hundred dollars. But if you have the $ you could go with a 6 piston caliber too. One of the guys at my HOG chapter has the PM set up and it looks great and he says stops great
http://www.performancemachine.com/mo...e-caliper.aspx
Old Feb 19, 2014 | 12:00 PM
0ldhippie's Avatar
0ldhippie
Bolt on the '08up Brembos.
Old Feb 19, 2014 | 12:44 PM
rerb95's Avatar
rerb95
I got 08 brembo calipers for sale.... Pm me if your interested.
Old Feb 19, 2014 | 12:52 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Newer bagger calipers with 11.8" rotors. LRB pads. I like the ***** Shiny chrome version as they grind off the Harley logo and chrome the screen and caliper body.
They bolt right up to your stock lower legs.
Old Feb 19, 2014 | 01:26 PM
roadking2014's Avatar
roadking2014
anyone try wilwood instead of Brembo for Harley Davidson? I had them on a custom bike.
Old Feb 19, 2014 | 03:21 PM
mdanehart's Avatar
mdanehart
I thought the 08 and up used DOT 5 brake fluid and not DOT 4 as on the 07 SG?
If that's the case how would the 07 SG front master cylinder accept the DOT 5 with swapping out?
Old Feb 19, 2014 | 03:28 PM
grbrown's Avatar
grbrown
There are various things we can do to improve brake performance, from replacing the stock hoses with steel braided lines, using aftermarket pads, changing rotors and pads, changing calipers. Lyndell make pads as well as rotors, although the Harley floating rotors work well.
I have 13" floating rotors and 6-piston calipers up front, which some may think a bit over the top, but I find they work fine!
Old Feb 19, 2014 | 04:29 PM
t059736's Avatar
t059736
I have installed PM calipers that XARAN has linked you to in his response.
One of the calipers I installed started to "chrome peel" after 3 months of time and a couple of very challenging rides.
The peeling chrome got into the pistons and ruined the front rotor.
Investigation revealed that about 50% of PM's front rotors fail due to poor chrome plating.
Mine was replaced by PM under warranty.
Something to consider.
As far as braking goes; there are none better.
Ride In Peace
LagunaGlide
Jun 23, 2019 08:44 AM
dojodragon
Dec 31, 2015 11:40 PM
Bikerdog44
2014-2024 Touring Models
Nov 10, 2015 11:44 AM
HDTimFLHX
Aug 17, 2015 03:00 PM
08sglide4me
May 3, 2011 07:49 AM
