HDPDPlus saddlebag quick detach
Old Feb 25, 2014 | 06:41 PM
geopac's Avatar
geopac
Default HDPDPlus saddlebag quick detach
I just ordered up the cable kit for my existing unit as my other cable got stuck and broke in the fairing. I was running the old cable between the lid and the bag and while it seemed fine I am looking for a cleaner look. Can anyone share how they mounted theirs to their saddlebag. Did you drill or slot a hole or just do what I was doing in the past. How easy is it to take off the saddlebag if you drilled a hole. From what I am seeing it looks like you can remove the ipod easily but actually removing the saddlebag will be a bit of work as you will probably have to wiggle the grommet out of the hole every time. I know HD has a different set up but it was a bit more.
Attached Thumbnails HDPDPlus saddlebag quick detach-saddlebagrelease-big.jpg
Old Feb 25, 2014 | 09:41 PM
camsmith's Avatar
camsmith
I found some grommets for a 3/8" hole, split em with a razor and fixed it this way...
Old Feb 26, 2014 | 10:29 AM
geopac's Avatar
geopac
Thanks CamSmith, that may be the ticket for me.
dmack1215
Touring Parts
May 18, 2017 08:25 PM
Redlegvzv
Mar 18, 2017 06:08 PM
BOSTONHAMMA
Touring Parts
Sep 23, 2014 11:17 AM
skiddd
May 10, 2014 05:54 AM
MOSTWANTED
Oct 18, 2012 02:43 PM
