Flat Tire Help
Old Mar 22, 2007 | 09:15 AM
Grover's Avatar
Grover
Administrator Emeritus
Default RE: Flat Tire Help
Depends on your comfort level.
1. Best - new tire
2. Patch tire and install new tube
3. Patch tire
4. Plug tire
You will find riders with each story and pro or cons.
Decide what your mental comfort is worth. The price of a new tire and installation.
Save a bunch and put a plug in it. Pull the wheel and pay someone to patch the tire.
Any way you go, someone will say there is a better way.
PersonallyI have a tire changing machine and a wheel balancer. I patch the inside of a tubeless tire and run it tubeless. Do the work myself and then balance the wheel, reinstall. It cost less than a buck for materials and takes about an hour to do.
JMHO
Old Mar 22, 2007 | 09:18 AM
sleepneagle's Avatar
sleepneagle
I carry a plug kit for motorcycles from Stop N Go. They tell you a plug is a temp repair to get you to where you can have the tire replaced. Replace the tire.
Old Mar 22, 2007 | 09:40 AM
dog155's Avatar
dog155
Take the tire to an auto shop,the new tire plugs will not give you any problems.I watched one put into one of our fleet vehicle tires and it is a permanent fix.
Old Mar 22, 2007 | 10:09 AM
LockNut's Avatar
LockNut
Grover,
Which tire changing machine and wheel balancer do you have?
Old Mar 22, 2007 | 11:45 AM
kingultra's Avatar
kingultra
my deal with not accept the liability of patch a MC tire. Pay the 175.00 so you are not thinking about it every time you ride
Old Mar 22, 2007 | 12:24 PM
gunrunner's Avatar
gunrunner
Ive run thousands of miles on a plug, its not a big deal. You probly dont have police run flats as they are not legal for consumer use and at least here in georgia dealers are required to remove them before selling police bikes. If your in cheap mode ,plug it, if not a rear tire is not an expensive investment.
Old Mar 22, 2007 | 12:38 PM
TowJam's Avatar
TowJam
You probly dont have police run flats as they are not legal for consumer use...
Any ideas why? They are consumer legal for automobiles.
Just curious...
Old Mar 22, 2007 | 12:43 PM
bikergirl40's Avatar
bikergirl40
In my experience, any good tire shop can easily and safely repair it. No need to buy a new tire.
Old Mar 22, 2007 | 12:50 PM
gunrunner's Avatar
gunrunner
ORIGINAL: TowJam
Just curious...
All I can tell you is they are Not D.O.T. approved for consumer use.
Old Mar 22, 2007 | 01:05 PM
392heminut's Avatar
392heminut
I got a basically new Dunlop from a friend of mine that he took off the rear of his metric because it had a hole in it. I put a patch over the hole, put a new tube in it and put it on my 77 FLH (spoke wheels). I've been running it like that for several thousand miles now with no problems.
