i was looking at my old 2013 SG the other day with a friend and the question of the front brake line came up. he has an even older 2012 with abs. on my bike it appears from the lever all the way down to the calipers it is one piece. is the abs bike different?
ok great, thanks. if any one has a pic of the seperate pieces that would be great.
so, that means if i were to put tall bars on thtat required new brake line, the non abs would be the entire line from lever to calipers and the abs bike would require the longer portion from lever to abs unit, correct?
ok great, thanks. if any one has a pic of the seperate pieces that would be great. so, that means if i were to put tall bars on thtat required new brake line, the non abs would be the entire line from lever to calipers and the abs bike would require the longer portion from lever to abs unit, correct?
Yes you are correct. However, you can get 2 piece lines for both bikes.
Geez, you must be rich to think a 2013 or 2012 are old.
Lol, no no no! I'm just ballin' on a budget here. But there are a lot of Jones' on here it seems with all the 2014s with a bunch of mods! But hey, good for them, I could never keep up with that!
