Worth doing head work??
Sent from my Galaxy Nexus
EDIT: Just to be clear, they did not tell me NOT to do higher compression. They were just honest about the issues and work that may be required to tune the higher compression builds (10.5 and up). It was my decision to take that as "advice" to keep it simple(r).
There's just too many variables to run serious compression on a bike you intend to tour on.
The TW-777, as others have said, like 10.5:1 compression. Your heads can be set up to achieve this compression. The heads will usually have some porting and texturing done to help with the air flow. A good set of heads set up to match your cam will give you some good results. You'll pick up some peak HP and fatten up your torque curve a bit with a good set of heads.
The other method would be to install some higher compression pistons. If you did this, you could bump the compression to 10.2 - 10.5. You won't pick up as much peak HP as you would with heads, but your low - mid rpm torque curve will be pretty close if not slightly higher than a 103 with heads. BTW, if your changing pistons you should be also going to a 107.
Personally, for a touring bike, I'd always go with displacement vs. heads if I had to make a choice with one or the other.
The TW-777s like 10.5 compression and head work. The "full enchalada" for the TW-777 would be a 107 at 10.5:1 and some matched up heads. That combination really puts these cams in their sweet spot.
Good luck.
PS - all of the above assumes your properly tuned
