tie down handlebar points?
Old Mar 8, 2014 | 08:33 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by hardheaded
buy a biker bar and never have to tie it down or compress your forks again. this is the best trailering device you can spend money on.you could turn the trailer over and your bike would still be on it.
yeah that!
http://ktperformance.net/i-9456846-b...r-touring.html
Old Mar 8, 2014 | 09:06 AM
bigheadted's Avatar
bigheadted
The one time my bike was on a trailer we learned from the dealer in Coos Bay a different way to tie the bike down.
He used soft ties around the fork lowers just above the fender attachment points.
At first I said no way but my Brother In law had just brought his bike over the Siskiyou's in a winter storm and the bike was still on the trailer after that rough ride.
Both bikes made it to Arizona no problem. You could see them happily moving on the suspension on bumpy roads.
After discovering the S&S frame mounted bracket if I ever had plans to trailer the bike other than a breakdown that is the way to go.
Old Mar 8, 2014 | 09:07 AM
bigheadted's Avatar
bigheadted
Originally Posted by soos
This is my obvious spot, where the front fender attaches to the fork. Rock solid and absolutely no compression on the front suspension.
LIKE this !!
Old Mar 8, 2014 | 10:30 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by jefla
With apologies for a mild thread hijack ... for the rear straps, what about attaching to the front exposed portion of the saddlebag support bracket? Bad idea?
Nope, that works just fine, I've been known to soft tie around the saddlebag guards. Just remember when cinching your straps up, this is not intended to hold the bike, but merely keep it from moving.
I don't like the idea of tying to the fender mounts.
To get it tight, you are pulling the forks apart, relying on the axle to keep it together. The strong support is at the top of the forks.
Not much room for a strap in there.
Not much room for a strap to get tight from there to the floor.
It creates a "pinch point" if you loop the strap there, compromising the integrity of the strap.
My 2 cents. YMMV.
Old Mar 8, 2014 | 10:37 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by mkguitar
DO NOT tie to the bars.
the bars are mounted to rubber bushings
if you crank down on them, you may deform the bushings.
repair requires pulling alot of stuff off to replace $5 in bushings
also the bars should be able to be be pushed out of position ( same with pegs/ floorboards etc.) this is so that if the bike crashes, the bars can't dig in and start a pinwheel
that's why the bars are not a good tie down location, they are supposed to be able to move
try strapping to the crash bar near the center bolt.
compress the forks about an inch ( do not crank them down, you can blow the seals)
make sure excess strap won't blow in the wind and scuff your paint ( DO NOT try to use a cover or tarp for same reason--- you'll be buying a paint job)
if using a locking type chock, make sure that the chock clears the rear portion of the fender when it comes up to lock - seen an ultra fender get damaged this way
Mike
And I learned the hard way, too.
Old Mar 8, 2014 | 11:21 AM
Boltsfaninmo's Avatar
Boltsfaninmo
Soos speaks the truth. I do exactly this. Bike in chock, tie downs from front fork tubes where fender attaches, and from the rear passenger pegs to the rear.
Old Mar 8, 2014 | 11:46 AM
wjl24's Avatar
wjl24
Those are the ticket. They work great and look fine on the bike.
Old Mar 8, 2014 | 11:49 AM
Leftcoaster's Avatar
Leftcoaster
Never had any problem tying to soft-ties at the bars where the bend is using a Pingel chock. If I was outfitting my trailer today I would include some kind of ride-on/ride-off chock. Right now I use a block underneath the frame to pull the bike down onto - works great, keeps stability high and tension low.
Old Mar 8, 2014 | 03:06 PM
hanny's Avatar
hanny
cool idea there I like it
Originally Posted by Weavr99FLHT
To the OP - you state that you do tow a couple times of year… what have you been doing in the past?
I have had just a flat bed trailer or pickup and pulled the tire tight up against the front of it with a couple tie downs and compressed the front end without any issues. That's what ive done for years but since this is my first bagger or heavier bike really and I got the new trailer I thot I would do it right. Everyones advise is very appreciated......... thxs for the help. Ive got the brackets ordered and got the Harley ratchet tie downs with soft hook to.....
And I'm really glad there weren't a lot of "Trailer? WTF ride that bit**" it would of been ok,,,, I trailer the bike on family trips and let them hang out with the inlaws and I ride,,,, LOL.
Old Mar 8, 2014 | 03:17 PM
Big L's Avatar
Big L
Smile
Originally Posted by SafetyMan
I've got an Atlas 1500 lift, so mine gets tied down quite a bit, I bought these that were mentioned above.. and it makes it easy.
http://www.harley-davidson.com/store...-down-brackets
I put some thick shrink tube on my hooks, just so the thin rubber on the hook doesn't get cut on the edge of the bracket and then damage the chrome and let it start to rust.
I got the same set up and used a small piece of cloth, but thanks to this thread going out into the trailer to get the straps to put some thick shrink wrap on my, "Big Daddy" straps. Thanks SM!
