107build acr
Old Mar 11, 2014 | 06:25 AM
joee's Avatar
joee
Default 107build acr
did a 107 big bore build on my 2013 ultra with big boyz head work red shift 657 cams bee hive high lift springs starts good and sounds good just have a popin at ideal it sounds like one of the acr in popin how do you know if one of the acr are bad how do i test them
thanks
Old Mar 11, 2014 | 07:22 AM
2009blackpearle's Avatar
2009blackpearle
Default i didi this
they open up when u push the starter button.. think its wire 19 on ecm plug. pretty sure u will have to pull tank off to get at acr plug connections under your tank.
pull spark plugs out and put a compression guage in one spark plug hole at a time. unplug connection to one acr with compression guage in spark plug hole. u will have to pull air cleaner off to force electric throttle plate open or reading will be lower or take longer to get compression up since butterfly is only open a hair for idling. with acr unplugged turn bike over pushing starter button get cylinder reading. then plug acr back in bleed off compression guage and test again , mine dropped about 45 lbs if i recall when energized.
move compression guage to other cylinder and repeat.
sure your exhaust gaskets arent leaking they can be a real bitch to seal sometimes and you will get a popping sound.
not sure if u would hear and acr popping since they vent directly into the exhaust port,
Old Mar 11, 2014 | 07:52 AM
joee's Avatar
joee
i will give that a try i that it was the exuust but it is not
thanks
HD_Matt
Engine Mechanical Topics
22
Mar 19, 2015 02:31 PM
britome
Dec 23, 2013 06:29 PM
Woods Glen
Exhaust System Topics
Oct 27, 2010 12:29 PM
timberwolfz28
Oct 17, 2009 05:49 PM
Todd Vikan
Screamin Eagle CVO Models
Apr 27, 2007 11:40 AM
