LED lighting question....
Old Mar 22, 2014 | 10:04 AM
blwright's Avatar
blwright
Default LED lighting question....
I am considering converting the front and rear turn signals to LED on my 2012 Road Glide Custom. I have been to the Custom Dynamics website and I read that if your bike is "BCM Compliant", you will not need a load equalizer. I don't know alot about automotive electrical systems. I've tried to research this but I can't find an answer. Have any of you done this mod to your 2012 touring bike and if so did you have to use the load balancing component ? How difficult is it to install the load balancer ?
Old Mar 22, 2014 | 10:27 AM
Pioneer74's Avatar
Pioneer74
You will need a load equalizer. Some require power from the battery. Mine from Kuryakyn plugged in line with the current wiring.
IIRC, most people that use Custom Dynamics bulbs use the Badlands load equalizer because it doesn't require power to the battery.
Old Mar 22, 2014 | 11:58 AM
03snake's Avatar
03snake
I have Dynamic Ringz (white outer running light and inner amber turns for the front, Amber turns for the back) (CDN SG with center HD taillight) plus a load stabilizer coming from CD. Your '12 RG requires the load stabilizer/equalizer. '14 touring's do not. It's very easy to install. Under your left side cover on the frame first pull the big breaker out. There is a plug with the wires running along the frame rail back to the taillight. Simply unplug it and connect the stabilizer (equalizer) in-line. Then run the pos and neg wires up to your battery and ty wrap the stabilizer somewhere convenient. Breaker back in and follow the included instructions to syncro them. They are very knowledgeable on the phone and have great tech support. The pictures below show the 6 pin connector for my CDN '13 SG (no beer box). The plug was under the bundled cable for the beer box so I cut the strap to get to it. Disconnect your plug to see how many pins, 6 or 8. Call them and they will tell you which one to order. I just ordered everything while on the phone. You can see in the picture the connector you plug in-line to. The badlands one does not require battery connections. CD products have a lifetime warranty.
Attached Thumbnails LED lighting question....-6pintail2.jpg   LED lighting question....-6pintail3.jpg   LED lighting question....-6pintail4.jpg
Old Mar 22, 2014 | 12:00 PM
rbferg's Avatar
rbferg
Like mentioned, you will need a load equalizer for your 2012 RG. I recommend the Badlands load equalizer, it's completely plug & play.
http://www.namzcustomcycleproducts.c...equalizers.htm
Old Mar 22, 2014 | 12:31 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I went with the Biketronics EQ, plug and play.
Some other makes require a power source, additional hassle.
Lifetime Warranty is a plus, too.
Me thinks dis be da one fo you...
http://www.biketronics.com/products/...Equalizer.html
Old Mar 22, 2014 | 04:09 PM
blwright's Avatar
blwright
Thanks for all the help. I am gonna place an order this evening !
Old Mar 22, 2014 | 05:04 PM
blwright's Avatar
blwright
I just placed my order with Custom Dynamics and I went with the Biketronics load equalizer....Now I can't wait for it to get here...LOL
Old Mar 22, 2014 | 06:18 PM
windrider24's Avatar
windrider24
3rd Gear
I went with the Dynamic Ringz and the CD load equalizer, I am sure you'll be pleased with the investment...I sure am!!
Old Mar 22, 2014 | 06:21 PM
SoCalMike's Avatar
SoCalMike
Originally Posted by rbferg
Like mentioned, you will need a load equalizer for your 2012 RG. I recommend the Badlands load equalizer, it's completely plug & play. http://www.namzcustomcycleproducts.c...equalizers.htm
You need a load equalizer. Badlands is an easier install ..... Plug and Play. I used CD on my '12 and it was fine.
Fast Aire
2014-2024 Touring Models
18
Oct 9, 2014 07:44 AM
paid4c4
Aug 31, 2014 09:40 PM
SmokerMI
Electrical/Lighting/Alarm
Jun 1, 2013 10:11 PM
Boozr
Dec 14, 2012 01:07 PM
turbo nasty
Product Reviews
Jan 15, 2006 05:59 PM
