12" monkey bar install? Help??
Old Mar 22, 2014 | 02:08 PM
Cearnhart91's Avatar
Cearnhart91
Default 12" monkey bar install? Help??
I am seeking advice on extending my break cables to fit my new 12" PYO monkey bars! I do have ABS. I have done my homework and ordered all the other correct extended items I will need to complete this process (barnette 12" tbw extension, magnum +8 clutch, namz 12" wire kit, and magnum +6 front upper break line) my question is: do I have what I need as far as extending my break lines or do I need a new mid break line to reach back to the ABS block. I'm just not sure if my +6 upper break line is all I need and I couldn't find a clear answer on this. A little help? Thanks guys!
Old Mar 22, 2014 | 09:50 PM
2807's Avatar
2807
You're in HB? Call Ed at Huntington Beach Hogs and Choppers
www.HBHogs.com
The end.
Old Mar 22, 2014 | 11:02 PM
Eagle Custom's Avatar
Eagle Custom
I just put 12" Monkey bagger bars on my 2013 abs streetglide and I only replaced the upper brake line so you should be fine. Fair warning pulling the wires is not a real easy job but take your time.
Old Mar 23, 2014 | 09:33 AM
Cearnhart91
Thank you thank you thank you! I'm glad to finally get a clear answer on this, I gotta buddy that owns a motorcycle shop that's gunna do it for me (I'm not not good at soldering) and I tend to break ****!
Old Mar 23, 2014 | 09:36 AM
Cearnhart91
www.HBHogs.com
The end.
I should check him out, my buddy Kevin owns bunks garage off of warner and beach! He hooks me up so I usually go there for maintenance and upgrades!
rowle
Dec 30, 2017 09:12 AM
Cearnhart91
General Topics/Tech Tips
Mar 22, 2014 01:51 PM
Cearnhart91
Mar 22, 2014 01:47 PM
Cearnhart91
Mar 20, 2014 11:12 PM
Bingee
Mar 15, 2009 07:42 PM
