Progressive Monotube Question
Old Mar 23, 2014 | 06:45 PM
Firechaser1141's Avatar
Firechaser1141
Originally Posted by sanman4ever
I've never heard of that? Where did you read that? Also it seems the amount of compression you have is normal.
Yeah new one on me
Old Mar 23, 2014 | 07:19 PM
MikeTD3's Avatar
MikeTD3
Originally Posted by littled62
when I put mine on last year I e-mailed Progressive about the clips, wanted to know if I need 2 or 3, they told me most of the time 2 works great 1 was for extra light people that ride solo all the time (under 150 lbs) 3 was very rare bike maxed out on weight, I am 255 or so and wife is 165ish and the ride is much better and almost no dive when braking but there is still movement in the front forks when I sit on it and when I hit a bump
Thanks for the info, I'm looking forward to trying them out.
Old Mar 23, 2014 | 07:21 PM
MikeTD3's Avatar
MikeTD3
Isn't one clip permanently attached and then you add either one of two against that....it's been awhile.
Mine came with no preload spacers installed, but 4 to work with.
Old Mar 23, 2014 | 07:45 PM
Ben E's Avatar
Ben E
You are still likely to have some dive, but vast improvement over stock. I found the monotubes a real benefit to handling, but not the end all of front end suspension by any means. They are worth it imho
Old Apr 12, 2014 | 06:21 PM
MikeTD3's Avatar
MikeTD3
I finally got a chance to ride today and the forks are much improved. They are firm yet compliant and soaked up the crap roads we have this Spring; money well spent!
Old Apr 12, 2014 | 09:07 PM
Douf's Avatar
Douf
The monotube cost/performance benefit is realistic in my opinion. There's only so much that can be done to improve the handling of an 800+lb machine. Out of idle curiosity - since unsprung weight has significant effect on handling - when mounting new tires on my Road King, I weighed the front wheel/tire combination along with similar items from a Honda CB1000 (the .....'Big One') and a Triumph Speed Triple. The Triumph combo weighed 25lbs, while HD's was 43! Even the - supposedly meaty - Honda's parts only came to 26lbs.
Douf
JekyllnHyde
Jun 19, 2019 02:26 PM
Gibbor
Dec 13, 2012 10:01 AM
eviltwin415
Aug 10, 2010 04:10 PM
mdanehart
Mar 20, 2010 10:42 PM
Dawg Rider
Jan 23, 2008 02:28 PM
