checking trouble codes on an 05.
Old Mar 25, 2014 | 07:02 AM
MOSTWANTED's Avatar
MOSTWANTED
Default checking trouble codes on an 05.
OK so my 05 king flashes the running lights and check engine lights in some weird way when I turn the ignition on. I have read it's because there are stored codes in the ecm. In me searches I found a procedure where you jump pins 1 and 2 on the ecm harness and cycle the ignition switch. Has anyone done this for sure as accurate procedure? I am a little nervous about jumping pins on my ecm not knowing whether this is correct or not. Btw the procedure came with a list of the codes.
Old Mar 25, 2014 | 07:18 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Jumping pins? No need.
http://www.cv-performance.com/harley...trouble-codes/
Bigdad68
Apr 28, 2024 05:40 PM
ieatchickens
EVO
14
Aug 28, 2018 10:17 PM
steelerdude1
Jul 22, 2012 04:16 PM
FloridaFLHX
Aug 28, 2010 10:51 PM
RMBob
Aug 15, 2006 10:09 PM
