clutch vibration
Old Mar 28, 2014 | 11:33 AM
Bigdaddychopshop's Avatar
Bigdaddychopshop
Default clutch vibration
Picked up an 09 street glide 44k. I noticed at certain speeds, the clutch lever vibrates, up and down. If u put a finger on it, it stops. Anyone else seen or experienced this? Supposedly just serviced.
Old Mar 28, 2014 | 11:54 AM
grbrown's Avatar
grbrown
There is an anti rattle spring in the lever designed to stop that! It may be broken, or have been left out.
Old Mar 28, 2014 | 11:55 AM
Baja38ss's Avatar
Baja38ss
Take a look at the black circular pin that runs down through the lever and through the
bracket. There's a c-clip that should be on the very bottom of the pin, that you might be missing. Or you need to adjust the free play on the clutch itself..
Old Mar 28, 2014 | 11:57 AM
Turbo Turtle's Avatar
Turbo Turtle
Not to worry, They all do that. These bikes vibrate more than the rest.
However that being said, their is a nylon bushing that could have been worn out by the previous owner. their in no standard "Service" that would take care of this issue, other than replacing the bushing. I do not know if just the nylon bushing is available, but I got a new one when I had to replace my lever from being hit by a car.
BOB
Old Mar 28, 2014 | 12:04 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Item #12 Part# 45021-86 http://www.tnt-actionsports.com/OEMp...7eCONTROL%5cKB
Old Mar 28, 2014 | 12:08 PM
Bigdaddychopshop
sweet! Thanks, sporties dont have those.
Old Mar 28, 2014 | 12:38 PM
TUCCI's Avatar
TUCCI
Too much play at the lever will have more vibration. I need to adjust mine before my next ride.
Old Mar 30, 2014 | 04:12 AM
mike_oh's Avatar
mike_oh
Your kidding...........right????
Old Mar 30, 2014 | 09:26 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
He wrote clutch, not right. This sounds like Chinese
Old Mar 30, 2014 | 10:56 AM
texaswiz's Avatar
texaswiz
I can appreciate the fact that you have a new to you bike. But, if that is the only thing that vibrates a little, consider yourself one of the fortunate few.
Tighten up the clutch cable just a tiny bit and go out and ride the hell out of that thing till something either falls off or it catches on fire.
