Custom Dynamics dynamic clusters installation ?
Old Mar 28, 2014 | 11:51 AM
skully1200's Avatar
skully1200
Default Custom Dynamics dynamic clusters installation ?
The instructions for these say that it may be necessary to drill a hole in the back of the reflector housing to run the wires that need to tap in for run/brake/turn function. I really like the idea of these lights, but the drilling part has me on the fence a bit. Anyone install these that can offer any feedback on the process? This would be on bullet style turn signals if that makes any difference.
Old Mar 28, 2014 | 11:56 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Since the cluster totally covers the reflector, it's non issue. The reflector just becomes a support for the cluster backing plate.
Don't over think it. Pull the reflector, drill your hole, run the wire, and slide the reflector back in
Old Mar 28, 2014 | 12:15 PM
onespeed's Avatar
onespeed
We have C/D turn signal cluster's on both our Road Glide and our Deluxe. Didn't have to drill anything. Plug and Play easy as it gets.
We love um.
Also lifetime guarantee which they do honnor. We had a few spots on the cluster of one that did burn out after about a year and a half. Just a phone call took care of it, no hassle.
Old Mar 28, 2014 | 12:23 PM
shooter5074
We love um.
I think he's talking about these
Drilling is required for these http://www.customdynamics.com/instru...c-clusters.pdf
Old Mar 28, 2014 | 12:36 PM
sanman4ever's Avatar
sanman4ever
It's easy....you have to drill. However when you drill the outer you come in contact with the little rubber inside. Be careful, I drilled to far because the rubber messed up my feel and I drilled into the wires.
All in all easy.....and well worth it.
Old Mar 28, 2014 | 02:50 PM
mirrmu's Avatar
mirrmu
Hi,
Yeah easily done like Shooter says, pull the reflector out, drill and when you put back in you have to really make sure everything right back to make sure get lense back on
Great product, these are run/brake/turn as become hardwired, no need for any module under seat
Thanks
Mirrmu
Old Mar 29, 2014 | 11:13 AM
onespeed's Avatar
onespeed
Originally Posted by mirrmu
Hi,
Thanks
Mirrmu
Yes you are correct on this. We have the module on ours. A little more expensive, but no drilling or splicing. You also have different flash patterns you can set to your liking. Trouble free.
Old Mar 29, 2014 | 12:43 PM
skully1200's Avatar
skully1200
Thanks for the replies. I will probably go ahead and order them. I had considered the triple play module, but I think I like the idea of different colors for the turn signals. I can add a strobe brake light in the center and it should be pretty eye catching.
Old Mar 29, 2014 | 03:31 PM
03snake's Avatar
03snake
I'm about to install CD Dymamic Ringz on the front and CD amber turns on the back. Bullet housings. Any issues having to trim the gasket or do the lenses snap right back on? Instructions say I might have to trim the rubber gasket.
Old Mar 29, 2014 | 03:33 PM
sanman4ever
Mine snapped right on....press fit style
