fuel question
Old Mar 30, 2014 | 03:56 PM
checkers's Avatar
checkers
Originally Posted by prezflyr
I know nothing about these tuners so is this a trip to the stealership once I purchase the slip on mufflers?
If you are referring to the XIED's, they are not a tuner, they are a fuel enrichment device. Google XIED and got to nightrider web site for a complete explanation, Cost about $100 and you can install them yourself
Old Mar 30, 2014 | 05:28 PM
bigsmos's Avatar
bigsmos
Did pipes and air cleaner on mine and added vance and Hines fuelpak bike runs great very simple to do
Old Mar 30, 2014 | 05:40 PM
Spider0408's Avatar
Spider0408
Originally Posted by wurk_truk
Correct. You can swap an AC all you wish to do. Mufflers and pipes are a totally different animal. The stock exhaust is what we have found holds things in check, not the AC. AC will only flow as much as the exhaust will allow.
Swap into different exhaust, you will, indeed, need to do something.
You say changing the intake air flow has no affect? And you say intake air flow is controlled by the exhaust pipes? I don't think that's correct.
Old Mar 30, 2014 | 05:52 PM
12hdrk's Avatar
12hdrk
Total flow is controlled by the intake thru to the exhaust. If the exhaust system restricts flow you can let all the air in you want with little effect. Open both ends and now you have a pump with more flow capability. Put your hand over your mouth and blow. Now open your fingers a little, then a lot. Flow changed because you put less restriction on the output.
Sent from my Galaxy Nexus
Old Mar 30, 2014 | 11:26 PM
Spider0408's Avatar
Spider0408
Thanks. I think I'll stick to the established formulas I've been using for air flow calculations instead.They work pretty good for naturally aspirated IC engines.
Old Mar 31, 2014 | 01:17 AM
mike5511's Avatar
mike5511
A very good, common sense example. (that many will ignore in exchange for what they already think they know.)
Old Mar 31, 2014 | 07:04 AM
12hdrk's Avatar
12hdrk
I can see you are already way above the simple explanations. Good for you. Not everyone is.
Old Mar 31, 2014 | 08:20 AM
btsom's Avatar
btsom
Closed loop fuel injection is capable of making real time adjustments based on exhaust gas composition sensed by the O2 sensors. Standard carburetors (not electrically adjusted) cannot adjust for altitude, temperature, humidity which all effect air density/mixture. It is my THEORY that the ECM can adjust fuel flow to adapt to changes in total flow up to the per-programmed adjustment limit. When that limit is exceeded it trips the engine light, most likely in this case with a "too lean" code. The ECM will increase injector dwell to maintain the factory air fuel ratio until the "that's not right" limit is reached. IF the factory tune is OK for a particular owner, why can't the air cleaner and mufflers be changed without a re-tune UNTIL the check engine light comes on. Now it really is too lean, but until that happens, the factory A/F ratio can be maintained.
Old Mar 31, 2014 | 09:39 AM
Spider0408's Avatar
Spider0408
I'm not above simple explanations. I'm above giving them out on topics I know nothing about. Not everyone feels the same. There are posts in this thread that demonstrate that very well.
Old Mar 31, 2014 | 10:08 AM
12hdrk's Avatar
12hdrk
Again you've proved my point. This is not the "internal combustion engine air pump theory" forum. Its about providing help to folks. If an explanation is too simple for the situation, in your opinion, please feel free to enhance or clarify. If you feel you are above that, or we are beneath you, then its best to not just throw jabs out there.
