12" PY apes installed
What did surprise me was the clutch only just fitted as did the throttle and brake.
It was the electric cable through the bars that required another 4" of cable!
Not seen this on this site but I'm sure that a lot of bikes are different form one another.
What I did was to allow a week for the work and take time looking at every part. Throttle, brake hose (although that was a bit longer to start with as it was braided s/s) were fine. Clutch will have to routed the other side of the crash bar for now.
If you need to lengthen the wiring, what I did was to cut away the outer sleeve but left 4" near the cluster as this has to fit the hole in the bars . measured the new amount needed and cut 12 lengths of new wire, mine were 4, any suitable length can be pushed around the headlight afterwards. Then cut the wires on the cluster at different positions so you can solder and heat shrink in different places so the cable is the same thickness along the length. Add a new piece of heat shrink to the loom and your done.
Feeding it through the bars can be done by dropping a small strong chain down and tying to that. Guide the cable through carefully so not to snap any wires and your done! Bit of lube helps push it through like hand soap or o ring lube.
Have fun!
Forgot an important bit, you will need a manual to explain how to remove the connectors, very easy but make sure you have taken pics and have recorded colors to numbers on the plug.
