Air Compressor Mount
Old Mar 29, 2014 | 08:51 PM
Grandslam's Avatar
Grandslam
Default Air Compressor Mount
Anyone installed an air compressor on a 13 ultra limited with ABS? If so, where did you install? I am not with my bike right now. Is there room inside the right side cover? Room for relay?
Any suggestions would be appreciated.
Old Mar 29, 2014 | 08:59 PM
puzzled1's Avatar
puzzled1
Viair 98C in front of the battery. Move all of the wiring and there is a decent amount of room in there.
Old Mar 30, 2014 | 11:19 AM
Grandslam's Avatar
Grandslam
That is where the compressor on my road king was mounted. I have been into this battery once to install heated gear wiring. It just did not seem like there was any room under the seat?
Old Mar 30, 2014 | 02:19 PM
puzzled1's Avatar
puzzled1
When you pull the seat it doesn't look like anything would fit in there! A little moving of the wires and there's a garage worth of space hiding in front of the battery.....
Old Mar 30, 2014 | 02:57 PM
Estil's Avatar
Estil
I just carry mine in a saddlebag. Mounting may be a better option though.
Old Mar 30, 2014 | 03:00 PM
Wander's Avatar
Wander
I've got my compressor mounted behind the right saddlebag. A couple of worm drive clamps wrapped around the body and the saddlebag support (slice of rubber for anti-vibration) and then two stainless steel zip ties going north and south around the compressor and the saddlebag mounting bracket. Solid as a rock and lots of clearance. As others have said with some imagination and trial and error there are a lot of spots to hide stuff if necessary.
Old Apr 1, 2014 | 08:02 PM
Grandslam's Avatar
Grandslam
Thanks for the replies.
Old Apr 1, 2014 | 08:27 PM
twistedcherokee's Avatar
twistedcherokee
puzzled1, what switch is that? TIA
Toby
Old May 31, 2014 | 09:19 PM
Joe6Pack_'s Avatar
Joe6Pack_
Wander
Would like to see some pics of your setup
Old Jun 1, 2014 | 05:05 AM
puzzled1's Avatar
puzzled1
Toby
That switch is from Arnott Industries.
