Having Trouble Checking Shock Pressure
Old Apr 1, 2014 | 12:54 PM
rcreechssr's Avatar
rcreechssr
Question Having Trouble Checking Shock Pressure
I have a 2013 Ultra Ltd with air shocks. Went to check the pressure and it measured 25 psi. Checked again and it read 15 psi. Used a dial and a stem type gage but it seems every time I put a gage on it the pressure drops by at least 10 psi. Is it just me? Am I doing something wrong? is there really that small of a volume in the shocks? Gimme a little help here!
Old Apr 1, 2014 | 01:01 PM
69cj's Avatar
69cj
There is not alot of volume in them. I use a Craftsman digital gauge and make sure I hit the schrader valve square on or you'll lose some press. How much depends on how quick you are. I've not had any problems.
bigheadted's Avatar
bigheadted
The shocks have very little volume and just checking could lose a good bit. I check with the pump as I seem to lose little air with the screw on end and I can pump a little in if needed.
If you are concerned it leaks you could pump them up to max and let it sit a day and check again? If loss then mix up a soapy water solution to apply to connections.
Over the years I have found very little air loss with the factory shocks. The connections need to be fresh cuts if you ever disconnect them. The fitting squeezes the air line and I have found that sometimes they will leak if you do not snip a little off the end.
Old Apr 1, 2014 | 01:06 PM
rcreechssr's Avatar
rcreechssr
No, I'm not concerned about leaks. I just like a firm rear suspension when riding curvy roads. I was going to adjust to about 35-40 psi as the dealer said they set them at 30. But when I put some air in and then checked it seems to drop significantly at each reading. It just didn't seem like I was losing that much. I know HD recommends a non-loss gauge, but geez, I can't believe my gauges are losing that much.
rbferg's Avatar
rbferg
You need a pump with a no air loss coupling. When I had air shocks, I never lost pressure with this style pump.
http://www.ebay.com/itm/60-PSI-Rear-...c3e119&vxp=mtr
Old Apr 1, 2014 | 01:12 PM
Hammz's Avatar
Hammz
Old Apr 1, 2014 | 02:36 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
That type really is the tool. It simply works. You don't need the Harley specific one, though it's not badly priced. The pressure is kept when you disconnect the pump/gauge.
Old Apr 1, 2014 | 02:44 PM
rcreechssr's Avatar
rcreechssr
Done. Good advice. Bought the one in your link. I had been struggling with the HD price.
Old Apr 1, 2014 | 03:05 PM
sixguns's Avatar
sixguns
After going thru the same thing trying to check and adj my air shocks,I picked up a Harley digital pump/gauge, while picking up my Harley oil and a new Harley T, then I went riding on My Harley. Works for me.
Old Apr 1, 2014 | 03:31 PM
bigheadted's Avatar
bigheadted
For kicks I went out and tried normal gauges on the shocks, I "lost" 2-5 lbs each time I checked. Amazing how a little psst of air drops the pressure so much. Using the suspension pump and gauge loses almost nothing.
