lowering blocks
Old Apr 3, 2014 | 09:33 AM
Brykwil's Avatar
Brykwil
Originally Posted by mountain man
I'd like to lower my 13 limited, however I find it hard to find any lowering kit to work with the HD touring shocks I put on. Anyone know of a lowering kit that will work for sure?? Thanx
It works on my 14 limited! On the LA chopper site it shows it fits your bike! Maybe give them a call .
Old Apr 3, 2014 | 11:38 AM
Pioneer74's Avatar
Pioneer74
Originally Posted by Brykwil
I like the LA chopper lowering blocks because the lower mount isn't at a extreme angle and it fits over the lower shock mount & bolts on to the swing arm. Solid design!
What about interference with the saddlebags?
Old Apr 3, 2014 | 01:38 PM
mountain man's Avatar
mountain man
E-mailed LA Choppers, explained I have HD touring shocks on a 13 ultra limited and they told me the shocks would hit there bracket and wouldn't work!
Old Apr 3, 2014 | 02:43 PM
12Iron883's Avatar
12Iron883
I have a 2014 SGS and I have tried installing the LA Choppers lowering blocks. In order to give the shock enough clearence you will need to use spacers. However, if you use the same spacers top and bottom your shock will hit the saddle bag. If you have a SG with the Harley air shocks you will not need the spacers but the rubber boot will rub against the lowering block.
I have also tried the road 6 style which changes the shock angle and again the SGS Premium shocks do not work with the 1" drop. You need to go all the way down to the second setting which is a 2" drop. I wasn't comfortable with the clearence after the 2" drop.
In the end I decided to sell my Premium Hand adjustables and get progressive 11.5 444's. I also did the low single cartridge premium front forks.1" lower in the front and 1/2" lower in the back did the trick. So far so good! It got my feet flat enough for me to beable to back the bike up while in the saddle.
Old Apr 4, 2014 | 08:59 AM
Brykwil's Avatar
Brykwil
None on my bike.
Old Apr 4, 2014 | 09:15 AM
Pioneer74's Avatar
Pioneer74
Are you saying you tried installing them with the hand adjustable shocks? I think you are only supposed to use the stock air socks with them.
Old Apr 4, 2014 | 09:18 AM
OLDDEADEYE's Avatar
OLDDEADEYE
I installed Pingel blocks. Yes they are more expensive, but Pingel has always put out quality products.
And some of those cheap *** blocks look scary as hell.
Old Apr 19, 2014 | 05:57 PM
Golfinds's Avatar
Golfinds
Do you experience any bottoming out with the 11.5s? Solo or 2 up? I have been considering progressive shocks and would love to get a half inch back but not willing to sacrifice the ride. Been looking at the 944s too, but many reviews on here don't seem to be impressed. Btw they are going on a 13 streetglide
Old Apr 19, 2014 | 06:00 PM
mattswit's Avatar
mattswit
2nd Gear
so cheap hope they work good
Old Apr 19, 2014 | 06:36 PM
LilWick's Avatar
LilWick
you need this...
lower it when needed and rides better than with the hand adjustable premium shocks when aired up. Wife can almost touch flat footed when down. Aired up it is easily an inch or more lower than stock.
