Custom Dynamics LED Issue
Old Apr 8, 2014 | 06:50 AM
SBW Cycles's Avatar
SBW Cycles
Default Custom Dynamics LED Issue
My father bought Customer Dynamic LEDS for the front and rear turn signals and stabilizer on his 2012 FLHX. He bought them in Daytona and brought his bike over to me to slap them on this past weekend (finally a decent weekend in NJ). Has anyone have any issues getting the lens covers back on? Once the LEDS are in, the lens cover does not want to go back on/doesn't snap into place.
He is also getting static on radio. I even tried installing the stabilizer's ground on a post in an alternate location as recommended in their instructions. I tried calling and got no help. Figured I would try here.
Front LEDS went in fine.
Of course a 10 minute job turns into a hour.
Any ideas?
Old Apr 8, 2014 | 07:51 AM
bissjim's Avatar
bissjim
Smile Stabilizer
If you get static on the radio then the stabilizer is bad. Had the same problem and a new stabilizer fixed that. Can't help with the lens covers not going back on I did not have that problem.
jim@hdbomm.com
Old Apr 8, 2014 | 07:58 AM
C.H.L.'s Avatar
C.H.L.
Have you called Custom Dynamics??
Old Apr 8, 2014 | 08:07 AM
tOSUSteve's Avatar
tOSUSteve
Can you get the lens on without the light in it? If not, then something is whacked with the lens or possibly he has different turn signal housings.
The static is from bad ground or bad equalizer.
Old Apr 8, 2014 | 08:13 AM
northeimcustom's Avatar
northeimcustom
as far as the lens, i heard of guys filing the flat spot on the prongs a bit so there is more clearance to seat
Old Apr 8, 2014 | 08:20 AM
KSGLIDEGUY's Avatar
KSGLIDEGUY
I recently installed mine and I believe there is something in the directions about that issue. I think it said to trim the gasket inside the housing.
Old Apr 8, 2014 | 08:41 AM
steelmonkey's Avatar
steelmonkey
5th Gear
Default custom dynamics LED issue
I installed mine on my FLTRU last week. Had to trim 3 of the 4 rubber gaskets in the directional buckets. Using a sharp/new razor blade made this easy. Hold the blade on an angle and trim down the gaskets using a circular motion. If you look into the buckets/housings you will see what I mean. I used a Biketronics signal equalizer because it is smaller and does not require a battery connection. This set up is working flawlessly. I do not think that this fitment issue occurs on flat style directionals. Hope this helps.
Old Apr 8, 2014 | 08:47 AM
SBW Cycles's Avatar
SBW Cycles
Thanks everyone for the responses. Lens fit without any bulb or LED in it. They are the stock red lens on the FLHX.
Didn't look at trimming the gaskets on the inside since I didn't have to do it with my Softail. I'll have to contact them about the stabilizer.
steelmonkey - is the biketronics stabilizer plug and play? Maybe I'll see if I can return the CD for my dad and get him the biketronics.
Old Apr 8, 2014 | 09:13 AM
tOSUSteve's Avatar
tOSUSteve
The biketronic equalizer is plug & play & does not require a hot wire.
Old Apr 8, 2014 | 07:01 PM
steelmonkey
5th Gear
As Steve says it is plug and play but it is also physically smaller. Figure about the size of a double thick Zippo lighter.
