As mentioned previous. With both cables in the slack position start with the throttle cable. You want it tight enough to where the grip does not turn very much before starting to move the throttle wheel. If you go too tight it will move the throttle wheel off the idle stop. I like mine on the idle stop with a very small amount of play. Check full throttle makes the wheel go to the other stop. There should be two stops. No throttle (idle) and full throttle. Tighten your jamb nut on the throttle cable at this point. Once you get to this point with the idle cable completely slack, what does the throttle do when you twist to full throttle and then let go? It should snap back due to the spring loaded throttle wheel. If it does not, then you have to find out if the grip is binding on the bar or in the switch housing..if it DOES snap back like it is supposed to then go slowly with the idle cable getting a little tighter at a time until it starts to bind, then reverse it until it again snaps back and then it is adjusted properly. Make sure that your cable ends are fully seated in the seats at the throttle body end.
The idea is that the throttle cable (pull cable) will open the throttle up when you twist the grip and the spring tension on the throttle wheel will close it upon letting go of the grip. The idle cable (sometimes called the push cable) is there so in the event of something happening and the throttle binds in the open position, you can manually roll the grip back to idle and that cable will close the throttle to avoid a stuck throttle/accident situation..
Great help everyone. This post in particular. To answer the question, with the throttle cable adjusted and the idle cable fully loosened, the throttle does return to idle. But not with the crisp "snap" action that it should. Or that it did before I started this project. I read up and got really familiar with the throttle stops and so I think I've gotten the throttle cable adjusted properly. But my understanding of how the throttle snapped back was wrong. I was thinking the push cable did that, but you're saying the tension to snap it back is really because of the throttle wheel spring. I think I read that somewhere, but I forgot.
Anyway, based on this ^^^ fact, I'm thinking the grip. I don't think it's the assembly of the switch housing. The first time I assembled it, I'm pretty sure I had the friction shoe a little off center, causing it to sit higher than normal and bind everything (including the throttle). Once I corrected that, that's when the throttle cable started working well. So something must be binding in the grip. (Note: I did make sure I backed the grip off a little, so it's not binding on the end of the bar. And the bars are new, so they are super clean and smooth. As are the grips... I thought). Guess I'm going to have to take it apart again once more. I did try putting on the old grip to see if it worked (and it did) but I stopped that experiment after initial assembly of the switch housing, without adjusting the cables. The old grip did roll on and snap back properly, although since not adjusted, it had slack in it and the throttle didn't open all the way. But that does give more credence to the ideal that something is binding in the grip. They are Kuryakyn ISO grips, by the way.
Did you change the routing of the cables at all?I got longer cables for my bars and routed them the same as factory. I had pretty much the same issue you are describing and after a bunch of messing with it,I changed the routing of the cables slightly and the problem was fixed.
Good question. I did not change the routing at all. Didn't change the cables either (Wild1 tech said I didn't need to. But then that's the same guy that said I didn't need longer wires either. Turns out, I DID). But since I went from a beach bar to a mini ape, the routing DID change somewhat, due to the height of the bar. That makes me wonder if it's binding somewhere else - and not in the grip - just because of the routing? Hmm...
Could be binding somewhere. How difficult was it to get the throttle end barrels into the throttle grip? If the throttle does not snap nicely back shut with the idle cable slack and the throttle cable adjusted correctly then something is binding. Could be where the grip sits into the housing. Could be the actual grip on the bar. Sometimes if the grip isn't sitting just perfect in the housing it can bind. Sometimes just getting it lined up perfect can be a pain in the ***. When I did my bars just here recently (03 classic) I was under the impression that stock cables would work. I put WO 515 on (10") I struggled and struggled to get my cables attached on both ends...finally bought 4" longer and they worked like a charm..you want both cables to not have slop in them but not tension either. When one of the cables has tension it can bind and if both are under tension it can really bind up. You don't want them fighting each other you want them working together. When one extends the other retracts and then vice versa.
Make sure that you did not accidentally tighten the daisy wheel that pushes against the friction shoe. Try loosening the two screws on the housing covers (a smidge) and see if that makes a difference. If that works, that means that something is not aligned properly inside. My gut tells me that the internal wiring loom is pressing against the throttle sleeve in some fashion. It is easy to have happen. Ask me how I know.....
yeah i didnt think about that is your grip is bigger in dia. that pad could be causing it to stick too, when i changed my stock grips out on my sporty i had to loosen the daisy wheel to make it work
Just because the bike was just serviced, don't assume the cables have been lubed. Mine did the same thing after I put on the extended signal switches. The cables were bone dry. Got some cable lube and all is well now.
Damn. WO515's is exactly what I've put on. This weekend I'll try move the cable locations around a bit. And also one more confirmation that the housing is assembled properly (I'm 99.99% sure it is). I know I get snap-back from the push (idle) cable when everything is loose. But not the strong snap back I'm used to. I'm really wondering now if I need longer cables... Crap.
So many people have done them without changing cables but mine absolutely would not go. Even tho my switch housing was in place and my cable housings reached I COULD NOT get the little ends (barrels) into their place in the throttle sleeve. Got them very close but no way. My brake line would not reach either so I replaced it too..clutch cable was ok...bizarre
So I thought I'd bring a little closure to this thread. Maybe. I took the right grip and housing apart this AM. Put the old grip back on and tightened everything up. Adjusted throttle. Tightening the idle only bound everything up. So it was a positive test. That is, the old grip worked EXACTLY the same as the new one. Rule out the new grip as a trouble source. Then I pulled the bars back a little, looking for any improvement. When I pulled them back absurdly far (down low like the original beach bars) there was some improvement. Houston, we have the answer! Its' the cable length. The stock cable doesn't like the height of the Mini Apes (10"). Unfortunately, since I live in a town house and have no garage, replacing throttle and idle cables is beyond my patience level or environment. I'm just not tackling lifting a gas tank out front here. (sigh #1). But at least I now know the answer! So I dropped the bike at a nearby reputable indie shop to get at least a new idle cable installed. My budget doesn't allow me to do what I'd like to do right now and switch all the cables to stainless (sigh #2). So I'll just get the one replaced in black. And it leaves me a project for some winter down the road...
Once I get the bike back from the shop, I'll provide the final closure on this issue. Thanks again for all the help debugging this. It was quite the learning experience!
That's very odd, I put the same exact bars on the same exact bike, and had
no problems at all with the length of the throttle cables. Yes, they are somewhat tight, but work just fine.
