better seat?
Old Apr 12, 2014 | 09:15 PM
Litewings's Avatar
Litewings
Default better seat?
Rode 230 miles today. My arss is sore. I'm 6' and 170 lbs. Ride my 2013 street glide solo 90% of the time. Like the looks of the stock seat but not the comfort for longer rides. Whats good that doesn't look like an overstuffed sofa?
Old Apr 12, 2014 | 09:22 PM
mikedanben's Avatar
mikedanben
I sent mine to a place to have it reworked with memory foam and my *** is more sore now. I am same size as you.
Old Apr 12, 2014 | 10:34 PM
J_ULTRA's Avatar
J_ULTRA
With the right seat you should be able to ride hundreds of miles with little to no discomfort. Harley dealers have "demo" seats try one out for a weekend. Also, I had a Heritage Springer that became increasingly uncomfortable after a couple of hours and almost unbearable after that. I purchased an "AirHawk" seat cushion for it and rode 900mi. over a weekend with no discomfort. A cheap alternative to getting a new seat.
http://www.airhawk.net/
Old Apr 12, 2014 | 11:22 PM
dirtdobber's Avatar
dirtdobber
If you are over 160lbs you need to add something under the memory foam. Like a gel insert etc...
Folks under 160 in most cases can do just memory foam and it also depends on what Foam they use-grade. Double layer helps with under 160lbs.
just a thought.
Old Apr 13, 2014 | 04:22 AM
2goldens's Avatar
2goldens
Just picked up a new Corbin Gunfighter in a distressed brown with red & silver stitching. Got a couple hundred miles on it and liking it so far. From the Corbin store in Ormond Beach, FL. About half the price of a comparable (in my opinion) Le Pera down the street at Destination.
But the comfort may just be dumb luck, as I didn't try any out before buying. I agree that you should try out a demo seat or two if anyone in your area has them. Then shop. Seat prices can vary greatly for models that have equal comfort for you.
Old Apr 13, 2014 | 04:28 AM
grbrown's Avatar
grbrown
Dozens of seat threads discussing this! Take a little time to browse recent ones.
Old Apr 13, 2014 | 05:04 AM
AmberWhisky's Avatar
AmberWhisky
Same here. My *** is more sore with the memory foam. Call the company that did the memory foam and they said it takes 800 to a 1000 mile for the memory foam to brake in. Whatever that means.
Old Apr 13, 2014 | 05:46 AM
Northwoodz's Avatar
Northwoodz
I still like C&C for the perfect combo of looks and comfort. They will build it any which way you want....memory foam, gel inserts, leather vinyl, etc. Still the best value out there in my opinion.
Old Apr 13, 2014 | 08:53 AM
Litewings's Avatar
Litewings
Have demoed a Sundowner and although it seemed better, I did not have enough time to take it on a long ride. Did not like the look either but may have to get used to that. Starting to think a solo seat and removable passenger pillion. Going to give the Airhawk cushion a look too. Thanks for input so far.
Old Apr 13, 2014 | 09:04 AM
digdug's Avatar
digdug
Who the F**k is under 160 that rides a Harley? Seriously though the stock SG seat does suck big time.
