Batwing removal
Old Mar 26, 2007 | 06:50 PM
vegashd's Avatar
vegashd
Default Batwing removal
I am trying to track down an electrical gremlin as in this thread
https://www.hdforums.com/m_1422097/tm.htm
I have the 6 push pins removed, the 3 windscreen bolts removed and the two bolts removed as well as the light and unplugged it. What am I missing to get the front part of the batwing off?
Old Mar 26, 2007 | 06:56 PM
Smitty0128's Avatar
Smitty0128
Default RE: Batwing removal
inside lower screws on the insde left and right?
Old Mar 26, 2007 | 07:00 PM
MrMcCool's Avatar
MrMcCool
What he said. Real inside. Tripple tree inside.
ORIGINAL: Smitty0128
Old Mar 26, 2007 | 07:13 PM
vegashd's Avatar
vegashd
is it attached to the front plastic piece?
Old Mar 26, 2007 | 07:15 PM
Smitty0128's Avatar
Smitty0128
real tight inside of , have to turn the bars to see the screw near the down tubes. Low and tight inside towards forks
Old Mar 26, 2007 | 07:20 PM
engineer's Avatar
engineer
There are only 5 screws if memory serves correct for removing the outer fairing. 3 are used to connect the outer, inner and to hold the windshield in place. 2 of them are on the back side of the fairing and are down between the forks (1 on either side). If you've got a street glide, the easiest way to do it is to remove the two from the back first because the outer fairing will drop when the last screw is removed without an auxillary light bar to hold it in place. After the screws are out, you just disconnect the connector from the back of the headlight. Let me know if you need a better explaination and I'll find a picture for you of the 2 screws on the backside. The service manual proved very helpful in getting this piece off for the first time.
Old Mar 26, 2007 | 08:45 PM
smknflms's Avatar
smknflms
See:
https://www.hdforums.com/m_126934/tm.htm
Later
Old Mar 26, 2007 | 08:48 PM
smknflms's Avatar
smknflms
..or with pictures:
https://www.hdforums.com/m_384080/tm.htm
Later
Old Mar 26, 2007 | 10:02 PM
vegashd's Avatar
vegashd
Ya, the last two were the ones I had left over... had to hold it up funny with one hand....
Old Mar 26, 2007 | 10:14 PM
HD Renegade's Avatar
HD Renegade
ORIGINAL: vegashd
Always take the top center screw out last, and put it in first to go back on. Makes it nice and easy for a one man job.
Bob
