Quick Question Tire pressure rear/ front
Old Apr 13, 2014 | 11:13 AM
grbrown's Avatar
grbrown
The sidewalls don't actually tell you anything useful, the notices are there to comply with some obscure regulation. Your owners manual or service manual gives pressures for solo and more air should be added if you are heavy, 2-up, or loaded to the gunnels. 36F/40R is a good starting point, but there is no reason why you shouldn't adjust those a little, if you want to change your ride. Also some brands of tyres use higher pressures than stock, so take that into account as well.
Old Apr 13, 2014 | 11:25 AM
Hausguy's Avatar
Hausguy
Originally Posted by glbtrotter
36 front, 40 rear. It's listed on the sticker of your front frame down tube.
I don't think this is the correct answer as different tires have different characteristics. For example, Michelin Commander II's need more air - at least 40/40 or else they are squirrely. Stockers are suggested at 36/40.
Old Apr 13, 2014 | 11:41 AM
bigheadted's Avatar
bigheadted
I agree.
Old Apr 13, 2014 | 11:43 AM
Brewmany's Avatar
Brewmany
Originally Posted by jdvorchak
...... Never go by any PSI listed on the tire sidewall. That is the maximum pressure that tire will hold and is not meant to be a guide for normal running conditions.
Not exactly. The pressure on the tire sidewall is not the maxium pressure the tire will hold, it is the maximum pressure the manufacturer suggests at which to run the tire. My Ultra's front is 41psi, and I gurantee that the tire can easily hold way more pressure than that. Harley's recommended pressure is on the bike frame downtube, for the tires supplied originally anyway.
Old Apr 17, 2014 | 05:31 AM
mayhemmaster's Avatar
mayhemmaster
Well i managed to get my fat head in there and have a read.....turns out both front and rear Specs @ 40 lbs
Strange tho..tires only had 22lbs in them...worst is i rode for 3 days to notice
Think they may have gone soft over Winter
Old Apr 17, 2014 | 05:42 AM
RK Joy's Avatar
RK Joy
Originally Posted by harleyultra1969
I think the book says 36 front 40 rear. I run the front a little closer to 40.
Yes, 36f / 40r. I have always run right at those numbers.
Old Apr 17, 2014 | 05:58 AM
Crex39's Avatar
Crex39
You are a brave man. I check mine at least once a week during riding season.
Old Apr 18, 2014 | 06:58 AM
grbrown's Avatar
grbrown
Red face
Tyres are not airtight! They do indeed lose pressure over time, so you really should check them if you haven't ridden for a while and especially after a winter layoff!
Old Apr 18, 2014 | 07:26 AM
Neckball's Avatar
Neckball
This only applies if you're running the OEM brand and size of tire. If you go to anything else, follow the manufacturers recommendation and not what's in your service manual or the sticker on your frame.
Old Apr 18, 2014 | 07:55 AM
roguebird's Avatar
roguebird
38f 42r. I'm currently thinking of upping a pound or two respectively. I noticed the poor handling as soon as I took off from dealer, it was reading 25f 28r. So have dealer double check when you pick up after storage or new purchase.
