Vance & Hines and O2 sensors 2011 SG
Old Apr 14, 2014 | 04:35 PM
*Road King*'s Avatar
*Road King*
Default Vance & Hines and O2 sensors 2011 SG
Questions
1. Stock headers have a "cat" material which generates the heat people are complaining about. Do the V&H true dual headers have this material or are they a clean pipe? I purchased my bike used (2011 SG). It has the V&H dresser duals with the O2 sensors. I came off an 02 RK, so I am new to all this Cat Chit.
2. Do people get rid of the O2 sensors all together?,
Old Apr 14, 2014 | 05:31 PM
Miccara's Avatar
Miccara
There is no cat material in the V&H Dresser Duals. Leave the O2 sensors connected. If you have a heavy breather as well, then you should have the V&H Fuelpak installed (or something like it). The O2's are bypassed in that case.
Old Apr 14, 2014 | 05:44 PM
RollaMo's Avatar
RollaMo
The pipes having or not having a catalytic converter, has nothing to do with them having or not having 02 sensors.
But to answer your question, the V&H head pipes do not have a "cat". But they do have the 02 sensor bungs.
If the tuner of your choice still uses the 02 sensors, you will want to keep them intact.
Some tuners do not use the 02 sensors, so in those cases you don't have to use the 02 sensors. You can just put a plug into the bung.
Old Apr 14, 2014 | 06:15 PM
*Road King*
The bike came with the SE race tuner with a dyno sheet stuffed in the box it came in. 85hp 103tq. The O2 sensors are still hooked up. The reason for the questions is because of the heat other riders are talking about. It hasn't got enough around here yet so I was planning for the worst but it seems what I have is as good as it is going to get as far as the heat is concerned.
Now I need to figure out what type of pipes are installed on my bike. They are not stock, they are slash cut type with no name stamped on them anywhere.
11'heritage
Mar 6, 2014 07:51 PM
nivensid
Feb 10, 2013 08:46 PM
Dannicus131
Nov 30, 2012 10:39 PM
papifun
Exhaust System Topics
Mar 7, 2011 12:14 PM
Undefined
Jul 14, 2007 12:06 PM
