Easy and Cheap DIY fix for leaking quick-release fuel fitting
The upper ring is thicker material but about the same diameter. It is designed to seal off the check valve/spring, it does not seal off the fuel line connector going down to the injectors.
Something else nice to know here is that to do this job correctly, you will need to use Viton "O" rings, which may not be what you are getting in the box behind the counter at Advance Auto parts.
I would consider any "O" rings from an "O" ring kit a temporary repair until you can install fluoroelostamer rings that will hold up in this new fuel.
I didn't mention it in my thread, but when mine first started leaking I had the correct size green nitrile "O" rings here, and installed one in the lower position so I could stop the leak and get the bike running again. That ring only last ONE day in this new fuel, and split and started leaking again!
I went to John Deere the next day and got their "O" ring that fits the lower position and it's fine.
I then ordered the correct repair kit to rebuild the valve from Fuel Tool and will replace both of the rings I installed as a temporary repair and put in the new ones from their kit.
Keep in mind here that both of those rings are on the down stream side of the filter. If you use Buna rubber, neoprene, or Nitrile rings (which is what is usually in those kits behind the counter at the parts stores) they are likely to end up coming apart and getting into your injectors........Cliff
" Keep in mind here that both of those rings are on the down stream side of the filter. If you use Buna rubber, neoprene, or Nitrile rings (which is what is usually in those kits behind the counter at the parts stores) they are likely to end up coming apart and getting into your injectors..."
Cliff,thats a very nice pickup & suggestion on your part thats a good reason to use proper viton oring seals because they shouldn't degrade & of come apart due to todays pump fuel with ethanol attacking them that could result in clogging up the injectors.
Scott
Some good reading here, although some of it is slightly "dated":
http://www.aquastik.net/apps/autofoc...09-01-0994.pdf
What really matters at the user level and relates to this topic, is that we can pretty much say for certain older FI bikes used "O" rings that were most likely Buna rubber or neoprene. I saw this with my 2002 CVO RK as both "O" rings were rotting away and chunking pieces off of them when I just happened to remove the tank last week.
I can also tell folks reading this is that there are a LOT of different grades of fluoroelastomer, and a lot of it is "dubbed" Viton, which is a trade mark of Dupont, but loosely used in many industry by folks trying to indicate that there products are of excellent or superior quality. In reality, a high percentage of those parts are nothing more than pretty blue or often black "soft" material that will NOT hold up in modern fuels blends.
I've upgraded some of the carburetor parts we sell several times to get a final product that will last forever in this new fuel. So when it comes to having a fuel leak issue with our HD's at the check valve and fitting, we need to make sure good "O" rings that are ethanol compatible are used to make the repairs.
Those two "O" rings are also somewhat difficult to obtain, and I would NOT trust the right size taken from any ones "O" ring kit behind the counter at a hardware or auto parts store. Most of those "kits" are cheap off-shore stuff, to be used at most for a temporary repair until you can get the right parts in there......Cliff
