Street Glide Seat and Adjustable Backrest
Old May 1, 2014 | 10:27 PM
Gasguzlr's Avatar
Gasguzlr
Originally Posted by rob0225
Not sure what I could have wrong.
I just installed one on my 2014 SGS, and mine opens the slit just a little tiny bit more than without. Is that what you're talking about, or is it significantly greater than before? I can barely notice mine, and it's only on the stock SG seat. I also picked up a Sundowner seat, and it is a bit higher so the slit is unaffected. I have to dig around a little in there to locate the mount before I can mount/dismount the backrest portion.
Cheers
Ross
Old Mar 2, 2015 | 11:40 AM
dubb77's Avatar
dubb77
Cheers
Ross
so the sundowner works with adjustable backrest? i tried a hammock and it wouldn't fit, now I'm on a hunt for a better than stock seat for touring two (wife hates the stock seat) up that works with that backrest.
Old Mar 2, 2015 | 01:38 PM
hog95023's Avatar
hog95023
Guys, does the adjustable backrest push up on the seat? Both up and forward? I just got a SG seat today and put it on and while it does fit...it pushes up on the seat and causes it to 'deform' and spread the slit open even without the backrest in.
it did on mine. The backrest bracket came too far forward. I was going to buy a modified bracket from wardspartswerks but they were out
I ended up buying a different seat. I tried Jason's personal bracket and backrest pad out and it worked great. My bike is an 09 streetglide
Old Mar 2, 2015 | 02:38 PM
Rustrtal's Avatar
Rustrtal
Yes, I use the Sundowner with a Tour Pak when the wife rides with me and run the stock SG seat normally. Pics in the link in the sig below.
hellbob37
May 23, 2014 01:39 PM
highaltidude
Touring Parts
14
Nov 24, 2012 09:55 PM
Udawg
Mar 13, 2011 12:05 PM
Mcook7373
Nov 21, 2010 06:18 AM
Stone1
Screamin Eagle CVO Models
Aug 19, 2010 02:45 PM
