Need paint advice and sources
Old Apr 28, 2014 | 02:14 PM
dplantz's Avatar
dplantz
Default Need paint advice and sources
Converting my 03 RK Classic FLHRCI to run hardbags instead of the leather covered plastic they come with
I found and bought some hard bags from a 04 Road King but I need to paint them first
My first question is:
How much paint should I order to cover both bags, 2 coats ? Do I also need a reducer or hardener? ( I read somewhere I did)
Where is best place to get the paint? I need Gunmetal Pearl 98603 BDT Apparently it is harder to find as is 100th anniversary model. I am OK with a non HD source too, esp because of the for sure higher price!
Old Apr 28, 2014 | 02:17 PM
dplantz's Avatar
dplantz
Default paint code
someone esle told me this
HD number off the can 9806BDT for the paint
99825-02 for the hardener
Old Apr 28, 2014 | 02:29 PM
santajim's Avatar
santajim
Colrorite.com I think is the site that mixes HD colors
Old Apr 28, 2014 | 02:48 PM
dplantz's Avatar
dplantz
yea, tried them they got nothing listing for
>> Motorcycle :: 2003 :: Harley-Davidson :: Road King Classic-FLHRCI
Old Apr 28, 2014 | 04:38 PM
hawg50's Avatar
hawg50
get your paint guy to look up the code for a 2003 harley davidson edition truck,the silver is the same.ask me how i know.any major paint store can fix you up with the ford truck paint.
Old Apr 29, 2014 | 10:28 AM
dplantz's Avatar
dplantz
Harley made a Gunmetal Pearl truck paint? Never seen one, only the black and orange colors
Old Jul 18, 2016 | 08:45 PM
BigBandlittleL's Avatar
BigBandlittleL
Stage III
Pls pls help this 20yr Service connected Vet 100% I need a pint of 2003 Gun metal blue pearl
Old Jul 18, 2016 | 09:47 PM
Ndfastln's Avatar
Ndfastln
what bike is it for?
Old Jul 19, 2016 | 11:01 AM
dplantz's Avatar
dplantz
got mine at cyclecolor.com $150 for a pint! But it matched perfectly
Old Jul 19, 2016 | 04:40 PM
steelerdude1's Avatar
steelerdude1
I personally like 2 stage paint, base coat / clear coat. The gunmetal Pearl may be a Tri-coat with the Pearl.
The easiest would be to buy it from colorite, but they are expensive. If you do a search, there are threads on here that list the ppg paint codes for just about all of the colors. It will be cheaper to go that route.
Typically the base coat will only use reducer, and the clear will have the hardener. You won't need much paint to cover the bags, you can get away with a 1/2 pint of base.(the 1/2 pint will mix 1 to 1 with the reducer, so you will have 1 full pint to spray)
You will need more clear than that becuse most clears don't get reduced.
Hope this helps.
LIVINtheLIFE
Jan 2, 2020 04:36 PM
mr_breeze
Powdercoat & Paint
Jun 24, 2019 04:28 PM
deno86
Feb 8, 2015 05:25 PM
bagman1
Powdercoat & Paint
Feb 15, 2013 07:43 PM
scubadude7
Sep 14, 2006 05:24 PM
