throttle cable return issues
Old Apr 29, 2014 | 04:19 PM
skydude426's Avatar
skydude426
Is your right hand grip pushed on too far so it's bottomed out and binding? Just a thought.
Old Apr 29, 2014 | 04:27 PM
rooti's Avatar
rooti
I had this same issue after doing bars on my dyna. It ended uo being a combination of issues.
1. You have to adjust the cable properly, there are video's out there.
2. Make sure your grips aren't rubbing at the end of the bars. You need to pull them out slightly.
3. You need to lube the grip with a small amount of dry graphite.
4. Lube the throttle cable
5. I also must have damaged the sleeve of my stock grip when I changed them over to the new bars. I had another stock grip I replaced it with and it worked much better.
Old Apr 30, 2014 | 05:21 AM
03electraglide's Avatar
03electraglide
What do you guys recommend to lube the cables with and what is best method
Old Apr 30, 2014 | 05:50 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
This is my favorite type of cable oiler. It's fast and effective. There are other ways to achieve the same end, but I prefer this one.
Make sure your new cables are the type to take oil before you oil them. Otherwise you may end up having to replace them.
John Barrow
General Topics/Tech Tips
Apr 12, 2017 10:40 PM
chad peterson
Jul 29, 2013 12:02 AM
teedub79
May 22, 2013 07:48 AM
Beerninja
Mar 25, 2009 10:29 PM
