Road King wobble
Think about a Fat Boy (solid) or an Airstrike (slotted).
Easier to keep clean and no maintenance.
You'll find many on Ebay and at breaker yards. You want a 3.00 x 16" with a 1" axle. You can swop 25mm bearings for 1" bearings if necessary.
Spoke wheels are worth dropping IMHO, at least on the rear, because eventually the rims will rust out too.
I doubt the previous dealer did anything to your wheel.
I am wondering what the design tolerances are, e.g. given that specific items such as crush tubes/internal spacer and side spacers could all be a variety of sizes ... even the paint on the arm is a couple of mm thick, or more.
It seems using the 2007 swing arm upgrade the pulley spacer remains the same and it is said that converting to a Brembo requires a 0.71" spacer on the other side ... but I am wondering how much and where it varies.
As for the Brembo caliper, it will need a 1" clearance hole, instead of the current 25mm, but the dimension required will be the same as the '07 caliper, if you have that. The thickness of the spacer required is the difference in thickness between the '07 brake arm and the Brembo one. I can provide those given time, but not quickly.
Tolerances ...
I've done my Brembo ... but it's cannot be a 1" exact, you need some tolerances somewhere in the set up.
Ditto on the spacer. It's said it needs to be .71" ... but there are so many other variables, from the bearings and crush tube spacer, to manufacture of the swing arm, to thickness of paint even ... how can it be so exact? Is it .71" plus or minus how much?
How much variability can there be?
Given that at least one year of Glides ran at, what was it, about an 1/2" of an offset on wheels, I suppose it does not matter ... but then perhaps it does in that some bikes are eating their bearings.
I wonder why?
Blueprinting one's rear fork ... now there's a new obsession! I was surprised how much the axle slopped up and down in the end. I must measure it so see what size it actually is.
I think it might be useful to go back and measure it all up, to see how many variances there are even in the width between the lugs and find out to what tolerances H-D works. I couldn't get the front bearings to sit equally either. It seems the crush tube is too long for a perfect fit.
I wonder why?
What is the 'crush tube' of which you speak?
The long inner spacer between the two bearings. It determines the distance between the two bearings, or how far into the recess the second bearing will fit.
If the lengths are not correct, and you torque it up, it'll put a sideways stress on the bearing which I am told - but do not know for myself - is the cause of some models eating bearings, particularly on the 25mm axles.
