2012 FLHTK 30T question
Old May 7, 2014 | 10:37 AM
Blt93932@aol.com's Avatar
Blt93932@aol.com
Default 2012 FLHTK 30T question
Hey guys, I'm planning on doing the 30t conversion, ordered a gates belt and the tri glide pulley, what else is needed? Someone mentioned to me primary gasket. Is there a part number or kit you guys have used that have done this? Thanks!
Old May 7, 2014 | 11:37 AM
SBates08's Avatar
SBates08
Here's a little food for thought...what's the likelihood of a dealer having that belt in stock if you were to break a belt while out on the road? Slim to none!!! My advice would be to elongate the slot for the axle by 1/4" and add the gussets along the bottom of the swingarm to strengthen that area. That way you can still run your stock 140 tooth belt. You will need the inner and outer primary gaskets as well as the 5 bolts that hold the inner primary on. They have orange gasket type washers on them and they are one use bolts. Below is a pic of a swingarm with this modification.
2010 Limited with some stuff
Old May 7, 2014 | 01:45 PM
grbrown's Avatar
grbrown
That's a good idea, but I have to ask how often does anyone lose a belt? I haven't over the last 24 years, including several lengthy tours. Having travelled through countries in Eastern Europe where there is not a single Harley or S&S dealer I am amused how you chaps worry about problems, while riding around the States!
Old May 7, 2014 | 01:59 PM
SBates08's Avatar
SBates08
I agree but it is a thought to be considered. And I'll almost bet the 139 tooth belt he ordered will be too wide.
Old May 7, 2014 | 02:09 PM
SBates08's Avatar
SBates08
My next question is what will you do to fix your speedo once you do this?
Old May 7, 2014 | 02:12 PM
grbrown's Avatar
grbrown
Red face
Probably the same as my 1 1/8" one!
Old May 7, 2014 | 02:22 PM
SBates08's Avatar
SBates08
Which will not work.
Old May 7, 2014 | 05:49 PM
Blt93932@aol.com
Gates poly chain 1" wide, recalibrate speedo with my power vision tuner. I could always buy a spare belt too, just in case. I found the inner primary gasket kit, looking for outer gasket, see lots of cosmetic primary kits online, but some look like they have 50 gaskets!
Old May 7, 2014 | 06:03 PM
SBates08's Avatar
SBates08
What's the part # for that belt?
Old May 7, 2014 | 06:23 PM
Blt93932@aol.com
PC-139-1 139T-1 INCH WIDE 14MM POLYCHAIN
Ordered from belt drives ltd
