True Duals
Old May 13, 2014 | 08:39 AM
ironhead3fan's Avatar
ironhead3fan
Default True Duals
Looking to get a true dual header setup for my 2003 FLHTCI. I see many different brands/options. I already have a set of V&H mufflers that I like, so I only need to upgrade the headpipes. Any preference to one brand over another? I already have a Power Commander, so I can easily accommodate the exhaust change. Thanks.
Old May 13, 2014 | 11:30 AM
skydude426's Avatar
skydude426
Vance and Hines are always a good option. We have a set on my wife's 06 Ultra. The fit and finish are good.
Old May 13, 2014 | 11:49 AM
Keithhu's Avatar
Keithhu
Even tho I have them, I'm not a fan of V&H. Call Fuel Moto, they have an opinion on which true duals perform best. MGS, Rinehart, S&S are better (stepped)
Old May 13, 2014 | 12:21 PM
crimson13's Avatar
crimson13
Check out dragosbikeworks.com
Old May 13, 2014 | 01:26 PM
ke5rbd's Avatar
ke5rbd
There are some that will convert to the 09 style with underneath crossover to get the left side heat off passenger. I know S&S has one and they work very good and sound good.
Old May 13, 2014 | 03:05 PM
dgdamore's Avatar
dgdamore
I had V&H true dual headers and would not get them again. On the '09 later bikes the crossover is so thin it looks like a piece of linguini. Also, my bike dropped 2 hp vs the stock headers when I dynoed it.
I'd look at S&S or see what the guys at FM recommend. The monster oval mufflers though sound great through true duals and I would use them again if I ever ran true duals but the power hit is more than I'm willing to take. (I gained 8 hp when I went to a 2 into 1).
Old May 13, 2014 | 03:11 PM
vickers1's Avatar
vickers1
I've used the V&H on my '03 and '08 and really liked them.
Old May 14, 2014 | 07:33 AM
skydude426's Avatar
skydude426
There are several good exhaust manufacturers that make true dual head pipes. I doubt it matters much which one you go with. From what I've found, the stepped headers others have mentioned require mufflers that will fit those particular heads. In other words stepped true dual heads come in full exhaust systems. You will loose some low end power with standard true duals but that's the trade off for the look and sound on true dual heads. I think my wife's Ultra performs just fine with true dual heads. Dyno sheets are great but it's the look, sound and feel as you ride that will make you happy, not the power your bike has at 5000 rpm.
Old May 14, 2014 | 08:08 AM
Murderface's Avatar
Murderface
Rush or MGS. Numbers are solid. Fit and finish are good all around. For more current model years O2 sensor placement is pretty on point (as is that of Fullsac).
Old May 14, 2014 | 09:01 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Have you ruled out Power Duals?
More power, and I like the look!
