Bias or Radial ??
Old May 15, 2014 | 01:28 PM
J-FRAME's Avatar
J-FRAME
Default Bias or Radial ??
Dunlop Elite 3 2000 FLHT with spoke rims and rim strips and tubes. Which do I need. Thanks
Old May 15, 2014 | 01:29 PM
decencyxdefied's Avatar
decencyxdefied
search my threads I had one of these a few months ago
Old May 15, 2014 | 01:30 PM
Pumba11's Avatar
Pumba11
Bias for your year bike. I ran two sets on my RK and really liked them.
Old May 15, 2014 | 01:33 PM
KCFLHRC's Avatar
KCFLHRC
TUBES
Tubes are a crucial part of the tube-type wheel assembly and should be treated with respect. When fitting a new tyre on a rim that requires a tube, a new tube should also be fitted. Old tubes can become stretched, and old tubes within new tyres can crease and fail due to thinning of the tube rubber. Tubes should only be repaired by an expert.
  • Secure tube valve assembly to rim with care
  • Inspect rim band and consult motorcycle dealer for correct rim band replacement
  • Always check the size markings on the tube to assure that the tyre size appears on the tube
  • Do not fit tubes in radial motorcycle tyres, nor fit radials on rims requiring tubes, unless the tubes bear matching size and radial (R) markings.
jmerchant.1
Wheels/Tires
Oct 19, 2015 06:24 PM
Globetrotter532
Mar 31, 2010 06:28 PM
archergodwin
Jun 10, 2009 12:49 PM
99FXST
Apr 20, 2006 03:23 PM
HDF Tech
Aug 7, 2005 03:59 PM
