Need some extended shifter pegs
Old May 22, 2014 | 11:29 AM
sharpshooter's Avatar
sharpshooter
Originally Posted by skratch
makes a lot of sense. you would need the spacer to move it out then (assuming you don't mind losing the heel shifter). also, maybe move the lever one tooth on the splined shaft, that'll give you more lift.
Skratch... I did move my shifter up a spline or 2. Initially I couldnt even get my boot under it. Im not to worried about the heel shift. I prefer the toe shifter anyways, All though I did notice after using the heel shift, when I went back to shifting up on the toe shifter it seemed alot harder to get in gear... Im thinking of switching to synthetics and maybe that will help some..
Zenglide, that's something like im looking for, but that particular one doesnt match what Im going for, thx though..
Old May 22, 2014 | 12:17 PM
DBLXX's Avatar
DBLXX
Had the same problem.....and I am all fixed up now.
Put a PINGLE peg extender on the front shifter, eliminated the heel shifter and added a pingle heel shifter eliminator and moved the toe shifter to the outside of the pivot.
LOVE IT NOW.
Old Apr 21, 2021 | 07:31 PM
Mike Starich's Avatar
Mike Starich
Stage II
Default 2005 v rod heel shifter
I’m new here .. Been trying to find a good cheap heel shifter for my 2005 v rod anyone able to help ? I checked M&m and they don’t cary one for my bike ..
Gizmo83
2014-2024 Touring Models
15
Oct 31, 2021 07:41 PM
ICE_BREAKER68
Mar 8, 2019 04:31 PM
Whiskyjock
Jun 2, 2013 02:03 PM
Tek74
Feb 13, 2011 12:23 PM
jjsanta
May 5, 2006 04:54 PM
